![]() | Home > General > Leaking anti-roll bar |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 214 ![]() ![]() ![]() |
Hi have you looked at Advance Factors a site supporter for this site ? Always found them good with quality and service for items I have purchased from them. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
I'm surprised the OEM one is that price. I'd have expected it to be c.£600-700 + VAT. 2012 SDV6 - it's missing a couple of cylinders
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
Front or rear ARB? 2010 TDV8 - current - my first RRS, loving it so far......
Be careful when buying something labelled as OEM. Sometimes parts are labelled OEM by the retailer and that's because the manufacturer is an OEM to Land Rover, for a completely unrelated part eg. a tyre valve cap. It doesn't necessarily mean they are the OEM for that exact part.
OEM (by BWI) unit at Advanced Factors: https://www.advancedfactors.co.uk/lr024073...4124-p.asp
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
Thank you everyone for the info.
Have you checked with Rob in R&E and also Steve at T&S normal to see what they come up with. 2006 2.7 TDV6 HSE in Cairns Blue. |
Update: I’ve had a new rear bar fitted. The bar was OEM and was manufactured by BWI. I’ve been lead to believe that BWI actually make the bars for Land Rover. It cost £499+ VAT from Island-4x4 if anyone is interested. |
Forgot to add that it now corners like it used to without it wallowing around. |
Baker3570 Member Since: 28 May 2021 Location: cumbria Posts: 53 ![]() ![]() |
hi sorry for jumping in on your post, did you fit the bar yourself or did a garage do it? if so how much was the total job as i think i could need one soon! |
Bought the bar myself for £600 inc vat and was fitted by a local LR specialist for about £400 in labour costs alone. I have been told that it’s not an easy job cos the chassis has to be unbolted from the body. The bar won’t come out without doing this. |
