Home > General > Leaking anti-roll bar
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
My ARB has been leaking for a few months now and I have been putting off having it done due to the cost of the bar itself. I have always just looked at the price of the Land Rover item and thought “Yikes!”. I think the leak may be getting worse and the oily patch on my drive increasing in size, so it’s time for a replacement.
A quick look at prices for a new ARB on the Interweb shows prices as follows:
OEM £499
BWI £700
LR £1500
all prices plus 20% VAT.
Anyone else changed their anti-roll bar recently and if so, which one did you go for?
Post #627367 Fri Oct 14 2022 9:58am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi have you looked at Advance Factors a site supporter for this site ? Always found them good with quality and service for items I have purchased from them. Thumbs Up
Post #627370 Fri Oct 14 2022 12:58pm
I'm surprised the OEM one is that price. I'd have expected it to be c.£600-700 + VAT. 2012 SDV6 - it's missing a couple of cylinders
Post #627372 Fri Oct 14 2022 1:54pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Front or rear ARB? 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #627375 Fri Oct 14 2022 3:15pm
knwatkins
Be careful when buying something labelled as OEM. Sometimes parts are labelled OEM by the retailer and that's because the manufacturer is an OEM to Land Rover, for a completely unrelated part eg. a tyre valve cap. It doesn't necessarily mean they are the OEM for that exact part.
You need to confirm the manufacturer of the part being labelled OEM.
The OEM for the active ARB was Delphi. Delphi sold out to BWI in 2010. BWI are now therefore the OEM. They are a reputable manufacturer and I would not hesitate in buying a BWI unit.
Here are some cheaper prices on BWI ARBs for you...
FRONT LR032958 (up to VIN 6A999999) @ £636.91+VAT https://www.lrseries.com/LR032958-BAR-FRON...EPLACEMENT
FRONT LR032959 (after VIN 7A000001) @ £636.91+VAT https://www.lrseries.com/LR032959-Bar--Fro...EPLACEMENT
REAR LR024073 @ £684.29+VAT https://www.lrseries.com/LR024073-Bar-Assy--Roll-NEW-REPLACEMENT Kev
Post #627376 Fri Oct 14 2022 4:01pm
OEM (by BWI) unit at Advanced Factors: https://www.advancedfactors.co.uk/lr024073...4124-p.asp
£600+VAT
Other versions on their site, of course. 2012 SDV6 - it's missing a couple of cylinders
Post #627378 Fri Oct 14 2022 4:56pm
Salisburylander
Thank you everyone for the info.
It’s the rear bar I need replacing. Several companies sell the bar as OEM, no idea who manufactures it. One company sells OEM and also the BWI.
I think the LR price is prohibitive and I won’t be bothering the local dealer for a quote…
Post #627384 Sat Oct 15 2022 9:52am
Stevepd
Have you checked with Rob in R&E and also Steve at T&S normal to see what they come up with. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #627388 Sat Oct 15 2022 10:33am
Salisburylander
Update: I’ve had a new rear bar fitted. The bar was OEM and was manufactured by BWI. I’ve been lead to believe that BWI actually make the bars for Land Rover. It cost £499+ VAT from Island-4x4 if anyone is interested.
Post #628327 Fri Nov 18 2022 5:08pm
Salisburylander
Forgot to add that it now corners like it used to without it wallowing around.
Post #628351 Sat Nov 19 2022 12:08pm
Baker3570
hi sorry for jumping in on your post, did you fit the bar yourself or did a garage do it? if so how much was the total job as i think i could need one soon! Big Cry
Post #628441 Tue Nov 22 2022 1:15pm
Salisburylander
Bought the bar myself for £600 inc vat and was fitted by a local LR specialist for about £400 in labour costs alone. I have been told that it’s not an easy job cos the chassis has to be unbolted from the body. The bar won’t come out without doing this.
Post #628443 Tue Nov 22 2022 1:41pm
