![]() | Home > General > 2008 RRS Keep or replace - sense check required! |
Would definitely want to test the various air suspension pieces and check codes before spending money.
Have a conversation with DM and get a realistic quote. That may concrete the decision to keep it. How much do you think it’s worth, £3-4k?. Not sure what I’d do but gut feeling would say keep it. Can you do the repairs in stages. Alternatively if you look at other cars for your budget what do you get age/mileage wise.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5045 ![]() ![]() ![]() |
get yourself one of them £80 FBH remote heater starters from ebay, to get around your Glowplug problem. |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Surely, it's what its worth to you.
GunnerBill Member Since: 24 Jan 2019 Location: Aberdeenshire Posts: 18 ![]() ![]() ![]() |
All of the above - great advice and thank you!
My FBH doesn’t smoke either, but I know it works each morning from fall to spring since the car is warm when I get in it. At some point I want to get the receiver and remote for it. For now timed heating/venting works. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Sentimental madness indeed |
"There really isn't a lot out there that can replace them besides another Range Rover!"
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9062 ![]() ![]() ![]() |
MY FBH on my SDV6 doesn't smoke either, so far as I know. There's the usual slight smell that is typical of them all, I think, but other than that and visible moisture/steam on a very cold morning, one wouldn't know it's there. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
So I'm quoted around £5,500 for:
You can’t take it with you |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 349 ![]() ![]() ![]() |
I'm not sure where these prices are comming from, compressor and air tank are less than £500 to buy and an hours labour to swop out on the driveway.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4470 ![]() ![]() ![]() |
Seems steep, but it does depend which suspension bushes were identified... |
Crossover pipe is not, I believe, a simple job. Might even be a body-off job. Of course, if it is, that makes changing the suspension struts easier as access is easy. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
