Home > Maintenance & Modifications > Gap IId tool help 2005 rrs Airbag issue
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Evening just wondering if anyone can help please? My airbag light is on. Im trying to pin down the faulty sensor.
I have an IId tool and im getting B0028 1b right side airbag deploy control.
I have looked at live values and i get 2.2 ohm's or there abouts for all sensors except number 7. (Drivers seat position)
Would anyone be so kind as to have a look on there iid tool to see what this reading should actually be please?
With the seat fully forward and fully back.
Im getting 10.2 ohm with it in either position so im thinking its likely a cable break. I cant seem to find any damaged cables under the seat and all contacts are clean.
Im at a loss now. Also does anyone know where the airbag module is? Ive removed the center console and fridge but cant find it.
Its a 2005 rrs many thanks.
Post #626988 Fri Sep 30 2022 5:38pm
looneyfitter
Post #626989 Fri Sep 30 2022 5:38pm
looneyfitter
Post #626997 Fri Sep 30 2022 8:23pm
this is what it looks like
https://www.ebay.co.uk/itm/254708318878?ha...R5i217XyYA
i wonder if its under the climte control or further under the dash.
someone on Disco3 must know,
Post #627014 Sat Oct 01 2022 12:44pm
https://www.disco3.co.uk/forum/airbag-depl...ght=airbag
https://www.disco3.co.uk/forum/found-airba...ght=airbag
Post #627015 Sat Oct 01 2022 12:50pm
looneyfitter
Great thanks Andy, mamaged to find it but seems the wiring is fine. Im getting high resistance on deployment control no.7. I was told it was the seat sensor but im not too sure as physical resistance i get on it is 4.9ohm yet my iid reads 10.2.
If i add a 2.2ohm resistor to the position circuit it shows a seperate fault as position sensor.
I dont suppose you have a list of what deployment is what do you?
Many thanks
Post #627024 Sat Oct 01 2022 2:40pm
I don’t sorry.
I think the resistance is of the pretensioner or airbag itself.
If you disconnect the seat yellow and orange plugs (one at a time) the change should be obvious on the iid
Post #627029 Sat Oct 01 2022 4:59pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I had this last year with my 2005. After a lot of checking my mechanic replaced the clock spring in the steering wheel which fixed it. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #627030 Sat Oct 01 2022 5:12pm
looneyfitter
Was that deployment 7 mate?
Post #627034 Sat Oct 01 2022 6:03pm
