Home > Technical > Alarm occasionally goes off without reason
AIJ 615
Thanks guys, I will bear this in mind
I will update if I find out any more
Can someone confirm if you double click the lock on the remote fob does this activate the deadlocks and also the sonic movement interior sensors ? That’s if my HSE 2010 RRS has interior movement sensors ?
Alan
Post #626887 Mon Sep 26 2022 8:26pm
On the pre-facelift cars if I remember correctly one press did the deadlocking and sensors a second press just did normal locking, however they did change the system to one press normal and a second press deadlocking, however I can't remember at what point they changed it, may have been with the introduction of the facelift model, mine is two presses for deadlocking.
Post #626891 Mon Sep 26 2022 9:09pm
AIJ 615
I may have another theory…..
So just had delivered one of them signal blocker pouches to safely out your keys in so the keyless entry can’t be amplified etc. anyway as I’m walking to me car on the drive with the pouch to test the keyless entry as I pull on the car drivers door handle it doesn’t open as I had hoped for however what I did notice was that the screen inside the car above the steering wheel said something like automatic steering adjustment
I’m thinking if I’ve double locked the car and activated the internal sensory alarm then maybe the steering column has self adjusted etc and cause the movement sensor to trigger setting the alarm off ???
Possible, maybe ????
Post #626892 Mon Sep 26 2022 9:24pm
Turn the auto steering adjust off and try again. Smile
Post #626893 Mon Sep 26 2022 9:50pm
AIJ 615
Hi guys
So yeah Alarm went off randomly again this morning so I’ve
A) Turned the Auto steering column positioning switch (I think this sometimes moves when the car is locked up causing the internal alarm sensors to detect movement ) ?
B) ordered a new bonnet switch as a few days ago the bonnet was 100% shut however when I tried to lock the car it made a beep, when I started ignition it said close bonnet. So I’m thinking first signs of a faulty bonnet switch so just ordered me a new one from Amazon for about £23
I’m not good mechanically or electronically but this looks very easy to fit, litterly unplug and then push the 2 clips and pull out and replace with new sensory and clip in place and reconnect 👌
Will update this forum on outcome
Al
Post #626901 Tue Sep 27 2022 12:00pm
AIJ 615
Hi Guys
So new sensor came today direct from Amazon (£22) fitted it like within mins so really easy to do. Fingers crossed that sorts out my random alarm going off issue
Fingers cross - will keep the group informed on progress
Alan
Post #626934 Wed Sep 28 2022 6:40pm
Stevepd
See easy. You’ll be changing the gearbox oil by the end of next week Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #626950 Thu Sep 29 2022 7:33am
AIJ 615
Hehe believe me that pushed me to me limits.
On a serious note love the knowledge in this forum from you guys, much appreciated
Al
Post #626954 Thu Sep 29 2022 8:08am
AIJ 615
Update : Day 1
RRS was double locked all evening and night and no alarm went off. Fingers crossed this has cured it
Alan
Post #626957 Thu Sep 29 2022 11:24am
AIJ 615
Final update : Gents unless I post otherwise I’d say I have solved and fixed this issue with of course the help from you find gents. New sensor fitter 2 days again and alarm not gone off once
Even when the thief tried to steal the car last night (joke lol)
Thanks all - you guys are best 👍
Post #626995 Fri Sep 30 2022 6:51pm
AIJ 615
Gents
1 week in and still no single alarm has gone off so the Bonnet sensor replacement has certainly cured the issue. Just want to report back on here for future reference for other members having same issue. For me at least this was my issue anyway and with the support and guidance from this forum group I fixed the issue
Thanks everyone that contributed and guided
Alan
Post #627159 Tue Oct 04 2022 5:22pm
