Home > Technical > Alarm occasionally goes off without reason
AIJ 615
Hi folks
Had my RRS 2010 LTE for a few days now however it’s happened to me 3 times now over 6 days that the alarm will suddenly go off. Any ideas ?
Is this a common fault issue ? Sensor maybe ?
Alan
Post #626797 Thu Sep 22 2022 8:09pm
Stevepd
Could be that the battery is getting low. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #626800 Thu Sep 22 2022 8:59pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Common problem, usually the bonnet switch. A quick fix is to join the 2 wires together.
Post #626801 Thu Sep 22 2022 9:12pm
AIJ 615
Oh my I think you have something here. I’ve only had the car just under a week however I keep getting error of low battery but I’ve taken it to Halfords and it’s 97% efficiency and also dealer said it was a fairly new battery. Maybe because it’s not been used much and say on forecourt ?
I’m going Blackpool in morning so maybe that will give it a good run and charge ?
Alan
Post #626802 Thu Sep 22 2022 9:20pm
NoExpert
Or the BMS wasn’t reset when it was installed. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626803 Thu Sep 22 2022 9:29pm
AIJ 615
BMS ?
Post #626805 Thu Sep 22 2022 9:42pm
AIJ 615
Further reading and it could possibly be the auxiliary battery ?
How can I check and is it something you can change yourself or a mechanic workshop etc ?
Where is it located ?
Alan
Post #626806 Thu Sep 22 2022 10:01pm
You don't have a Aux battery on a RRS1 L320. BMS battery monitoring system, basicaly it keeps a eye on the battery charge state, if the charge level drops it start to shutdown various circuits so you have enough charge to start the vehicle in theory. Don't get to excited about it as they periodically self calibrate anyway, mine has thrown up low battery occasionally since day one nearly 10 years and never failed to start, one thing I would suggest assuming it is practical to connect it depending where you park is buy a Ctek charger, especially if you do not use the vehicle for several day's at a time.
Post #626807 Thu Sep 22 2022 10:08pm
AIJ 615
Ok cheers Col
So I’m now thinking then it could possibly be this common switch under the bonnet. Is it easy for a novice to fix, any instructions anywhere
Post #626808 Thu Sep 22 2022 10:18pm
Bent paper clip and bridge out the connector temporarily to check if that is the issue, if you do a search on the forum there have been a few post's about it.
Post #626809 Thu Sep 22 2022 10:23pm
AIJ 615
Post #626811 Fri Sep 23 2022 1:55am
Stevepd
https://www.rrsport.co.uk/forum/topic56598.html
and
https://www.rrsport.co.uk/forum/post471986.html#471826 2006 2.7 TDV6 HSE in Cairns Blue.
Post #626812 Fri Sep 23 2022 6:41am
AIJ 615
Appreciate the support guys
Loving this forum as a newbie RRS owner
Al
Post #626817 Fri Sep 23 2022 9:06am
NoExpert
Do you have the interior sonic sensors for the alarm? Mine seem to be aggressively sensitive and pick up the dash expanding. In the summer I’ll run the A/C so the interior is nice and cold, park in the sun and 10-15 minutes later the alarm will go off without anything happening other than the car heating up in the sun. Same on colder mornings when my park heater kicks on and the dash starts getting warm. Mine has done this maybe ten times over the last year and typically occurs with the inside hot or cold and the outside temps are the opposite. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626819 Fri Sep 23 2022 10:06am
Dave B
My Disco had a lazy seat belt, and when it finally decided to fully retract, it was enough to set the alarm off.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #626823 Fri Sep 23 2022 3:59pm
