![]() | Home > Technical > L320 4.2 v8 supercharger MOT fail |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
Very possible but start looking for a vacum leak 1st and check long and short term fuel trims |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
spoke to mot tester he said the emissions test was showing it running to lean |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
where did you get it done? halfords? |
engine management light was on I took it off but these fault was stored
🤣🤣🤣 local garage up road from me |
I would still be looking for a vac leak |
I'll have a look around over the weekend |
can the sport breaks system be bleed like a normal car or will it have to be done by diagnostic like the p38 ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5094 ![]() ![]() ![]() |
I think it depends on how much of the system you have disturbed, if just replacing fluid or fitting new flexi brake pipes etc. can be done the old method with a jar and tube, pressure bleeder or vacuum pump etc. If the hydraulic control unit etc. has been removed, replaced for example I believe it has to be bleed via diag. equipment to I assume open various valves/solenoids. I am in the near future about to change the fluid and renew the flex pipes on mine so did read up on it a bit. As a point of interest when I replaced the accumulator and steel brake pipes on my old P38 certainly never connected it to any diag. tool to bleed the system.
thanks for that it both the rubber hoses from the front callipers that failed
quick update took the rr for a long drive on Saturday put it in command shift left it in 4th gear (at the advice from a mechanic) to get the cats hot 30 mile round trip parked it up left over night
if you can look at live data with a diagnostic tool;
thanks for that I'm just waiting for chap with diagnostic to let me know when he free later to do a live check on every thing and see what the readings are |
update
