| RRSPORT.CO.UK | ||
|  | Home > Technical > L320 4.2 v8 supercharger MOT fail |
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 359      | Very possible but start looking for a vacum leak 1st and check long and short term fuel trims | ||
|  Fri Sep 16 2022 2:55pm |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | spoke to mot tester he said the emissions test was showing it running to lean | ||
|  Fri Sep 16 2022 3:13pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | where did you get it done? halfords? | ||
|  Fri Sep 16 2022 3:15pm |
 engine management light was on I took it off but these fault was stored
|  Fri Sep 16 2022 3:16pm |
 🤣🤣🤣 local garage up road from me | ||
|  Fri Sep 16 2022 3:17pm |
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 359      | I would still be looking for a vac leak | ||
|  Fri Sep 16 2022 10:15pm |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | I'll have a look around over the weekend | ||
|  Sat Sep 17 2022 5:30am |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | can the sport breaks system be bleed like a normal car or will it have to be done by diagnostic like the p38 ? | ||
|  Sat Sep 17 2022 5:29pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I think it depends on how much of the system you have disturbed, if just replacing fluid or fitting new flexi brake pipes etc. can be done the old method with a jar and tube, pressure bleeder or vacuum pump etc. If the hydraulic control unit etc. has been removed, replaced for example I believe it has to be bleed via diag. equipment to I assume open various valves/solenoids. I am in the near future about to change the fluid and renew the flex pipes on mine so did read up on it a bit. As a point of interest when I replaced the accumulator and steel brake pipes on my old P38 certainly never connected it to any diag. tool to bleed the system.
|  Sat Sep 17 2022 9:10pm |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | thanks for that it both the rubber hoses from the front callipers that failed
|  Sun Sep 18 2022 5:20am |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | quick update took the rr for a long drive on Saturday put it in command shift left it in 4th gear (at the advice from a mechanic) to get the cats hot 30 mile round trip parked it up left over night
|  Mon Sep 19 2022 7:24am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | if you can look at live data with a diagnostic tool;
|  Mon Sep 19 2022 1:49pm |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | thanks for that I'm just waiting for chap with diagnostic to let me know when he free later to do a live check on every thing and see what the readings are | ||
|  Mon Sep 19 2022 2:43pm |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | update
|  Sun Sep 25 2022 8:14am |
| Posting Rules
