Home > General > Worn wheel bearings
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Worn wheel bearings
If I turn left there is a rumble from the front right. Is this a wheel bearing calling it a day? My car has done 122k miles.
Post #625896 Thu Aug 04 2022 11:26am
Mickmac
England 2007 Range Rover Sport TDV6 HSE Java Black
I had exactly the same symptoms as yours ,it was indeed wheel bearings ,I changed both side
Post #625976 Sat Aug 06 2022 7:43pm
Salisburylander
My car is in the garage at the time of writing and it has been diagnosed with a worn wheel bearing. Interestingly, there is no movement on the bearing but definitely sounds graunchy when the wheel is turned.
Post #626043 Wed Aug 10 2022 11:27am
aaronjb
Had the same on mine at similar mileage - replaced both fronts, although only one was noisy, on the basis that if one has gone the other probably isn't far behind (IIRC it was the N/S/F which is also the one getting the most loading on roundabouts).
Wasn't too costly a job, thankfully! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626045 Wed Aug 10 2022 12:06pm
Gandalf
"Wasn't too costly a job, thankfully!"
Just been quoted over £600 for both sides, Censored might get My BFH out Very Happy If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #626051 Wed Aug 10 2022 2:39pm
Salisburylander
The bearing was very corroded and the chap at the garage brought it out and said “Here you go! Try and turn it!” It was virtually seized solid. The mount had also corroded to the arm. The scars on the old bearing showed the battle between man and machinery.
Booked it in for the other one to be done.
Post #626055 Wed Aug 10 2022 5:08pm
NoExpert
Was it missing any rollers? That’s when you know a bearing is extra crispy. I did one a few weeks ago missing eight rollers, and the guy drove it in saying it needed brakes.
I’ve only had a really bad fight getting one out so far. We remove the bolts, then put longer bolts in from the back and beat the snot out of them to get the bearing to come out. We also put a curved metal plate over the CV joint to protect it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626057 Wed Aug 10 2022 10:26pm
aaronjb
I paid £495 at the local indy.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626059 Thu Aug 11 2022 11:21am
Salisburylander
There weren’t any bearings missing but they were just worn out. A bit like my knees these days… 🤣
The replacement unit was manufactured by Timken; I have been told that these are the same as the Genuine Land Rover ones.
Post #626060 Thu Aug 11 2022 12:28pm
NoExpert
Timken are good bearings. Watch out for FAG, just received one with Made in China on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626061 Thu Aug 11 2022 2:36pm
Salisburylander
A quick update: both bearings have now been replaced. The low rumble that was ever present has now disappeared and there used to be an occasional knock on the steering, that hasn’t happened again either. 👍
Post #626207 Sun Aug 21 2022 11:26am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Thumbs Up Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #626208 Sun Aug 21 2022 11:38am
