Home > General > Worn wheel bearings |
Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16 |
I had exactly the same symptoms as yours ,it was indeed wheel bearings ,I changed both side |
Sat Aug 06 2022 7:43pm |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 239 |
My car is in the garage at the time of writing and it has been diagnosed with a worn wheel bearing. Interestingly, there is no movement on the bearing but definitely sounds graunchy when the wheel is turned. |
Wed Aug 10 2022 11:27am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Had the same on mine at similar mileage - replaced both fronts, although only one was noisy, on the basis that if one has gone the other probably isn't far behind (IIRC it was the N/S/F which is also the one getting the most loading on roundabouts).
Wed Aug 10 2022 12:06pm |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
"Wasn't too costly a job, thankfully!"
Wed Aug 10 2022 2:39pm |
The bearing was very corroded and the chap at the garage brought it out and said “Here you go! Try and turn it!” It was virtually seized solid. The mount had also corroded to the arm. The scars on the old bearing showed the battle between man and machinery.
Wed Aug 10 2022 5:08pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 425 |
Was it missing any rollers? That’s when you know a bearing is extra crispy. I did one a few weeks ago missing eight rollers, and the guy drove it in saying it needed brakes.
Wed Aug 10 2022 10:26pm |
I paid £495 at the local indy.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Aug 11 2022 11:21am |
There weren’t any bearings missing but they were just worn out. A bit like my knees these days… 🤣
Thu Aug 11 2022 12:28pm |
Timken are good bearings. Watch out for FAG, just received one with Made in China on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Aug 11 2022 2:36pm |
A quick update: both bearings have now been replaced. The low rumble that was ever present has now disappeared and there used to be an occasional knock on the steering, that hasn’t happened again either. 👍 |
Sun Aug 21 2022 11:26am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
Barrie.
Sun Aug 21 2022 11:38am |
