![]() | Home > General > Body Off |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Loosen and tighten the top mount nuts for the struts? If you need to replace the struts, not having them seized from a decade plus of crud would make the job easier. With the body off, access to the nuts is simple.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 ![]() ![]() |
when my turbo went in my l322 - I purchased 2 off ebay and got the garage to change both while the body was off 2016 Range Rover Sport SDV6 autobiography (MY17)
When mine was body off to replace the crossover pipe, I had them replace the fixed brake lines that run along the chassis. Easy peasy with the body off. 2012 SDV6 - it's missing a couple of cylinders
