![]() | Home > Technical > My logic has gone out the window |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 214 ![]() ![]() ![]() |
While trying to sort out why my compressor goes on and off, looking at the front and left valve percentages and gallery pressure , the percentages at the front are going from 0 percent to 100. While the pump runs .Would this be the front valve block at fault , at the same time the gallery is filled to 8_900 kpa probably psi and then when the pump stops the pressure drops again.
Not sure what more I can say , or what might make it clearer.Basically the front is not rising. The compressor raises the pressure, then stops . Restarts when the gallery goes down to 300kpa , brings the pressure up againto around 8 to 900kpa, but no elevation of the front , what I'm trying to establish is , is the front block to blame or the block next to the pump.As I say the front corners start flashing 0_ 100 percent while the compressor is pumping , the rear doesn't do this they are extended and stay there. After a day or two they have come down now to about half their height. Not in this fault , I'm guessing.Hope that helps you to understand yhesituation |
Trying to edit last post so apologies, the phone is not working for me ! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5054 ![]() ![]() ![]() |
The computer raises / prioritises the rear first.
The disco forum will provide more help.
I have just renewed the drier filter , exhaust solenoid and seals and it pumps up to about 900 kpa/130psi.
Ok , something to try thanks.
So the front has dropped by about 30 to 40 cm,They have stayed unequal as well.\i dont know , is it leaks , probably . Espacially if the pump keeps bringing the pressure up. So if I have pulled the fuse , can I assume that its ether the front valve block or sensor after ruling out my new plumbing when fixing leaks. |
I have just taken F26 out over 24hrs at full height and the front only has dropped 20mm each. Can I assume that the front valve block is defective. |
Well the front block could do with new seals which are about £20 off eBay. |
Thanks Andy , just wanted a nod to track in the right direction, worth a try anyway. Ordered !
Looks like a leak on yellow line coming back from front block. |
