Home > Technical > My logic has gone out the window
Page 2 of 3 <123>
I think that goes to the front left strut ?
Post #625452 Fri Jul 15 2022 6:46pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Two black lines do that , the yellow which I disconnected and immersed i water showed the leak. O the back of that it was showing both fronts went down with the fuse 26 out. Im sure if that is yhe end of it though as the compressor never really reaches max pressure. In saying that I filled up the gallery again and released the line at the same point behind the tank at the compressor valve block and a serious amount of air was trying to escape, At that point I was sure wether it was line release or valve block next to compressor. I then went to the front and quite a leak was showing there. So ordered seals and a new block , probably not genuine.
Post #625458 Fri Jul 15 2022 7:34pm
alfapat
Compressor still taking too long and locks the suspension,
I have now taken middle valve block out to remove seals there and replace with new.
Post #625641 Sat Jul 23 2022 11:33am
alfapat
Leaking tank , rusted next to chassis was the cause .
Car pops itself up quite quickly after 24hr Park. Which I know this is not correct but tat least the compressor isn't struggling now .
How much if any , should the car drop in 24hr period.
Post #625823 Tue Aug 02 2022 11:49am
They shouldn’t drop at all.
But when 10 + years old is not unusual for the front to drop over night
Replacing seals and cleaning dust in the front block usually fixes it
Post #625826 Tue Aug 02 2022 2:20pm
alfapat
It's minimal drop the front block has been replaced , so I'll go with that thanks.
Post #625897 Thu Aug 04 2022 11:31am
alfapat
Looking at my last post, it's reads that I was being flippant, so sorry for that but I wasn't just saying thank you for your help there. Yes it still drops a little but a lot better than it used to be .I ca
n even put it up or down with the key buttons , useful sometimes.
Now the hydraulic valve block has sprung a leak at the filter cap , corrosion has set in on the lip that houses the o ring seal, and haven't managed to overcome this yet , unless I find a s/h one at a reasonable price. I don't relish the thought of lifting the body work again ,as I did for replacing the pipes to the front.
Has anyone changed the block without a body lift.
Post #626256 Wed Aug 24 2022 10:33am
What is the pictured part ?
Post #626257 Wed Aug 24 2022 11:34am
Dynamic Responce Valve block with filter and retaining plug removed, looks like it's had it's day as well.
Post #626258 Wed Aug 24 2022 12:03pm
alfapat
YES SPOT ON . I have found a dowty seal that supports the rear of the seal to hopefully stop it being pressurized out at that corroded part. Just lost a bit of shoulder , I have eased this into the o ring recess , along with the O ring and used hydraulic seal on the filter plug threads. I have given this a 24hr cure and just put in oil again , so watch this space, I'm not that confident as the dowty seal has moved off centre as I torqued it up. More time and a drive is needed , the oil is so expensive , but like everything else these days .
Post #626265 Wed Aug 24 2022 8:28pm
Disco_Mikey
Fingers crossed it works
Blocks are currently unavailable, either genuine or aftermarket Big Cry
Post #626266 Wed Aug 24 2022 8:35pm
aaronjb
What are the valve blocks made out of, Mikey? I'm assuming this is a reasonably common failure with age & corrosion and I'm wondering if the sealing area could be built up with weld and then machined back.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626270 Thu Aug 25 2022 8:45am
alfapat
Alloy , would be a lot work , possible to add some alloy weld , and then re machine, but tricky spot in my case.
Post #626271 Thu Aug 25 2022 9:02am
Could you possibly use something like JB metal repair paste to rebuild the corroded part, not sure it would work but just a thought, although the pressure might be to much.
Post #626272 Thu Aug 25 2022 9:46am
aaronjb
Doable but not on the car would be my thought there then - and cast aluminium is highly variable in terms of how easily you can build it up, but.. dismantle, clean, boil contaminants off with pre-heat, TIG the area up, remachine the sealing surfaces.. a lot of work, don't get me wrong, but if parts are unobtainum.. Smile
Probably best done on an exchange basis though.
[edited for speelung mistooks] 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626275 Thu Aug 25 2022 11:00am
Page 2 of 3 <123>
