![]() | Home > Faults & Fixes > Weird Electronic parking brake fault |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5123 ![]() ![]() ![]() |
wELL YOU NEED TO READ THE FAULT CODES.
RangeSportTDV831 Member Since: 27 Mar 2022 Location: Toulouse Posts: 8 ![]() ![]() |
Hi Andy,
I think the ELM only gives engine codes from memory
Hi Andy,
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 ![]() ![]() ![]() |
The electronic park brake (EPB) is a known fault and a cheap and easy fix - if thats the Problem.
So what you advice me to do ? Thanks |
Definitely read the codes first. Previously owned 1999 Disco 2 TD5
Here are some news ! I just received my Autel and did a Diag and I get this code for the EPB : C1A00-4B |
That code appears to indicate that the park brake module has tripped a temperature overheat for whatever reason, possibly someone has used the park brake a little excessively over a short period, maybe bedding in new shoes or something like that. Looking at fault code below you may be lucky and by clearing the code it may go away. Where it says suspect a internal fault with the ABS module, I think that may be a L/R misprint and actually mean the park brake module not the ABS.
Thanks a lot for all those precisions ! I have erased the DTC but it keeps on coming back.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
Why don't you simply service the brakes,, open them up,, clean and lubricate where necessary then adjust correctly and then see where you stand. After that if there's no improvement start looking into the brake module. You can play all day with a handheld unit but if there is a mechanical problem you need to get your spanners out and cure the fault. Dirt does not do these systems any favours. 2010 RRS, TDV8
Okay roger that ! I will try to remove everything and try cleaning the shoes and see if anything change. By the way when I’m on the road driving and lift the switch I can get emergency brake and the car brakes until it stops completely ? |
To be honest, I wouldn't be making a habit of doing that,,, get it working correctly first. 2010 RRS, TDV8
