Home > Maintenance & Modifications > Replacement Dynamic pipes question.
Page 2 of 3 <123>
Disco_Mikey
Front dampers can be taken off and binned. They are not required Thumbs Up
Post #623947 Fri Apr 29 2022 7:47pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Cheers , less expense! Any tips on bolt removal, other than weld a new nut and keep a fire extinguisher handy!
Post #623949 Fri Apr 29 2022 8:41pm
alfapat
Disco_Mikey wrote:
We have stock on the newer part number, LR015144
Retail at £305 + VAT
I expect RQA500120 will be obsolete, and supercede to the above number Thumbs Up
Order accepted on that number, old number , all good though, thanks.
Post #623963 Sat Apr 30 2022 3:58pm
alfapat
Ah well I'll blog on, bolt head would no take a weld, must be made of dissimilar metal, tried every combination of society and eventually ground off the head. Unfortunately now I'll have to release the the rest of the two rears to extract the remaining stud! And yes the pipes are are nightmare to pull out, one to go. I think I've got the body high enough now.
Post #623964 Sat Apr 30 2022 4:46pm
alfapat
AH ! The suspension components, I left the suspension at full height, and had to remove the drop link and then the top arm, problem arose with the feed pipe to air spring, not protruding enough to catch the cooler nut and so wary of snPping the pure through it locating hole at the top of strut plate, any suggestions, perhaps just feed it through carefully as I remove the bag?
Post #623989 Sun May 01 2022 6:38pm
Disco_Mikey
Drop link comes off
Flexi pipe needs unbolted from hub carrier and top arm, but they can both stay on
Undo the driveshaft nut and push out the hub
Lower the shock down and undo the pipe when accessible
Earth strap off the body
Post #623990 Sun May 01 2022 7:03pm
alfapat
ALL DONE THANK YOU .
Also needed to drop front oilcooler ,old pipes out but I need some more room for new set up.
Post #623993 Sun May 01 2022 10:25pm
alfapat
Yeah tricky that pipe , got a bit squashed but still whole , I think.
The four new pipes must use the inserts left in hyd block, doesn't seem like new ones are supplied.Its a weird set up for sealing pipe joints.
Post #623996 Sun May 01 2022 10:32pm
alfapat
From my sized body bolt that rounded, A wee bit of luck after two hours, getting an answer to extracting the remains!
Post #624006 Mon May 02 2022 1:44pm
alfapat
Tried to edit earlier, apologies, meant to say seized bolt.
Anyway after a big effort releasing new pipe clamps , those pipes do not want go in easily at all , what an effort As long as they don't leak I'll be happy .
Post #624019 Mon May 02 2022 8:28pm
alfapat
Got a question , the front four pipes came (as anyone who has done this) with clamps , keeping everything in place. I think they're fitted back to front comparing them to the old section lying out. It's just that they aren't happy lining up to the new rubber mounts I have screwed to the chassis leg.
Obvious thing is to turn them the other way.
They have a right angled lip to the bottom , and at the moment they are turned outwards.
Does Anyone recall correct fitment.
Post #624049 Thu May 05 2022 9:53pm
Disco_Mikey
Angled bit goes to the bottom and towards the chassis
Post #624051 Fri May 06 2022 6:55am
alfapat
👍That solves it Mike thank you.
Going to ask you Mike , and you might not answer, I have heaps of Dexron 111 , and I can't see it is much different from RavenolCold climate or L/R 's Cold Climate other thN temp range . The D111 is GM6417M and its not D11, what do you use yourself, and what do you know , if you have any idea that would be useful.
Post #624052 Fri May 06 2022 8:20am
Disco_Mikey
https://www.jgs4x4.co.uk/discovery-power-s...venol-ssf/
Ravenol SSF
DExron doesnt meet the required specs
Post #624054 Fri May 06 2022 12:17pm
alfapat
ORDERED !
Two forward three back, just went clean and paint swan neck pipe on the aux water cooler an it rotted through . £194 for that pipe, no way. I will go and make up a rubber one with hose tails.Cant believe that , somethings are quite reasonable with Land Rover and others .....Well !
Post #624058 Fri May 06 2022 8:45pm
Page 2 of 3 <123>
