![]() | Home > Maintenance & Modifications > Replacement Dynamic pipes question. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
Aux cooler can be bypassed |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 215 ![]() ![]() ![]() |
I see does seem a bit excessive , now spent £12 quid dammit! Bit bulky but done , why would you need this ?
Was standard on all pre facelift TDV8s
Is that pipe affordable Mike, the link I made up is causing all sorts of problem in plastic fittings . Around inner shield and bumper, although I've fashioned it a bit . I like things as they should be, but maybe that link you used, is simple enough If I remove the matrix I could use the joints I have , they are just double house tails and a pipe. |
Had to take the bumper off again for the umpteenth time! Inner arch was not right,. I researched the face-lift pipe and it was £200 , so redesigned my new link, and create more space. Tried to get s/h original pipe but it seems they are also rotten, and if they aren't they are sold with the radiator. |
Trying to move forward here, first of all I've found a garage with snap on to possibly bleed my unit .
Again , looks like no assistance here.
Just to add 18hrs later with the the 20 amp fuse out F26 the rear suspension is unchaged but the front drivers has dropped 3.5 mm and nearside 4mm .Front driver was at 51mm and nearside 55 .That is taken for consistancy at the base of the centre cap.
Struggling to achieve full height, as in off road height? |
yes, especially drivers,. have it all stripped on full height at the moment and doing some leak detection on front valve block. |
Ok found the pipe connection to the front drivers strut leaking.
