Home > Wheels & Tyres > Hunter alignment. Anything I need to know beforehand?
Stevepd
I’m having new tyres fitted and Hunter alignment done on Saturday. It’s my first time having the car Hunted. I read today that the car should be full of fuel. Is it an internet myth, would never have guessed that. Anything else I should know?. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #623835 Mon Apr 25 2022 9:12pm
Not sure just how much difference it will makes but this is from w/shop manual.
Post #623841 Mon Apr 25 2022 10:49pm
Stevepd
Cheers Col. Well it must be there for a reason. Thanks for confirming what I thought was internet tosh. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #623846 Tue Apr 26 2022 5:57am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I've had 3 Hunter alignments and never knew this and the technicians have never mentioned it! I can see the rationale.
Steve - you'll get a printout of before and after adjustments. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #623848 Tue Apr 26 2022 6:35am
Buckster
I would check that all of your suspension arms, bushes and associated components are all in good order. Otherwise you will be getting the alignment done to then disturb it by having to change something, you will then have to get it aligned again! Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #623850 Tue Apr 26 2022 9:01am
The vehicle should also be be put in to "tight tolerance" mode for the alignment. This just means the suspension works harder to get as close to level as possible. Technically, a Hunter place should have a dongle to set this but most don't as it's an expense for them if they don't do many LRs. Most will just leave the driver's door slightly open to stop the suspension moving around.
If you have an IID Tool, you can set tight tolerance using that, just remember to put it back to normal once done or your EAS system will be working overtime. 2012 SDV6 - it's missing a couple of cylinders
Post #623862 Tue Apr 26 2022 5:00pm
Stevepd
Thanks everyone. I’ve got an IID tool so am happy to set prior when I arrive on site. Next how do I do that within the settings? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #623866 Tue Apr 26 2022 5:42pm
Tool Menu > Service/Test > RLM-Suspension > Set Tight Tolerance - Yes. Don't forget to take it out of Tight Tolerance when done. Easy as. Very Happy
Post #623874 Tue Apr 26 2022 11:52pm
Stevepd
Lovely cheers. Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #623877 Wed Apr 27 2022 6:04am
gogsy1956
Surely if your paying someone to carry out 4 wheel alignment you shouldn't have to do anything,,, they should know exactly what is required and have all the tools to carry out the job. I had mine done a few years ago at my go to place (( team valley landrover) issued prior to going about full fuel tank etc, they said it makes no difference. They use a Beisbarth ( spelling may he wrong) machine. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #623887 Wed Apr 27 2022 2:25pm
Maybe if they say "it makes no difference" then they don't know what they're doing. Whistle Rolling with laughter
Or maybe Land Rover are just being silly by saying "full tank of fuel and tight tolerance mode is required".
Or a bit of both, most likely. Rolling with laughter Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #623892 Wed Apr 27 2022 9:37pm
Simple solution have it done with empty fuel tank and not in tight tolerance mode, see what the readings are, then fill the tank, put it in tight tolerance have it checked again and compare the readings, if it makes no difference they should both be within the specified parameters. I know L/R do like to complicate things somewhat, but you would like to think they say full tank etc. for a reason.
Post #623895 Wed Apr 27 2022 10:28pm
Indeed so, Col.
What is strange is why they made the suspension so adjustable in the first place. It's like a race car's suspension compared to most road cars.
I have had a play on a Hunter system - changing ride height does change camber but doesn't change toe. It does alter the wheelbase very slightly, however. 2012 SDV6 - it's missing a couple of cylinders
Post #623897 Wed Apr 27 2022 11:03pm
Stevepd
An update to this. I rung last week and asked for the tyres I wanted (Continental Allseason Contact), they said no problem and a discounted price of £213ea from £224 was agreed. I received a text message the following day to say my tyres were in. So this morning I set off and went the 30 miles or so and they got going. They found the 2 NS wheels were buckled so I approved to have them repaired. All done I paid my dues which was cheaper than the amount I’d budgeted. I drove home and the drive was so smooth and back to how I remember it. This has also fixed my problem of the reluctance to change into sixth. When I got home I had a look at the tyres and read the receipt and they have fitted 275/40 R20 Continental Sport Contact 4x4s’. Now this is a summer tyre when I was looking to go to an all season. I’ve re-googled the original tyre and I can’t find them in my size, so obviously my mistake. So I feel it’s my fault for not researching further. Also with regards the free alignment within 3 months - they don’t do that anymore but would for me as if spent so much money.
Post #623961 Sat Apr 30 2022 12:57pm
syl
I’ve had my car aligned (not my RRS) several times over the years, including on a Hunter machine.
I have NEVER got the car back with the steering wheel exactly level when the wheels are pointing directly ahead. Maybe I am a bit more OCD than most. It always has to go back, sometimes more than once. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #623976 Sun May 01 2022 12:48pm
