![]() | Home > General (L494) > Annoying Interior Rattle From Rear on 2021 RR Sport! |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1904 ![]() ![]() |
Have you checked the boot latch? 2023 P440e SE Dynamic on order -cancelled
Sir_Les Member Since: 14 Jun 2021 Location: Leicestershire Posts: 16 ![]() ![]() |
No, what specifically should I be looking for or checking please? |
Try some insulating tape around the fixing in the boot, sometimes the latch rattles against it. 2023 P440e SE Dynamic on order -cancelled
HaggisMan Member Since: 24 Apr 2018 Location: Glasgow Posts: 139 ![]() ![]() |
I had what sounds similar at the front of the roof lining on my last RRS (2019). After extensive investigation it turned out to be the pano roof that wasn’t sealed properly. It rattled more when the temperature was a bit warmer / sunny but it drove me nuts. I’ve posted extensively on it elsewhere on the forum so have a look for the posts and see if that might be the same for you but at the rear |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 549 ![]() |
I have a similar rattle from the rear of my SVR…likewise it is mega frustrating because it is so loud.. it sounds as though the tailgate is rattling in the hatch opening.
It went into local Range Rover dealership last week and they have narrowed it down to either roof ladder around pan roof or the pan roof itself that is rattling.
Taken 6 months to sort but Range Rover have sorted it, turned out that the hinges on the boot had dropped and that is what was making the rattle. Sturgess Range Rover sorted it all under warranty.
poolman Member Since: 28 Oct 2017 Location: bournemouth Posts: 1 ![]() ![]() |
my son had the same problem with his new r/rs it was traced to the pipe that takes the water to the rear washer and is above the roof lining. Hope this helps |
