Home > Technical > Electrical Gremlins RRS 2007 L320 3.6 V8. Car stereo and car |
RossL Member Since: 28 Nov 2021 Location: West Lothian Posts: 9 |
This just started as an intermittent fault a few days ago, the car alarm would go off, I'd just unlock and relock the RR with the key fob, all good....for a little while...rinse repeat.
Fri Feb 11 2022 2:34pm |
No sunroof, seems dry inside apart from the odd bit of condensation on the windows during wet weather.
Fri Feb 11 2022 5:03pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4808 |
your initial problem of the alarm going off, is usually down to a faulty bonnet switch (bypass it with a paper clip). It part of the latch on the drivers side.
Fri Feb 11 2022 5:30pm |
Thanks for the response, that hazard lights being on I feel were part of the alarm but I was sat with the door open and the key in the ignition.
Sun Feb 13 2022 10:10am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
The above link doesn't work?
Sun Feb 13 2022 12:20pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
There are many places CAN issues can occur
Sun Feb 13 2022 1:07pm |
All appears to be well now regarding this issue. Not sure if it was caused by the heavy rains we had but I'm assuming I got a bit of water ingress into he wiring, will need to investigate further once I have her back.
Tue Feb 15 2022 1:59pm |
See if the top label on the headlights say AFS
Tue Feb 15 2022 5:43pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
There was a post on this very issue just a day or two ago,,,, if my memory serves first suggestion was to check the earth's behind each headlight, but apparently the fault was the small motors that drive the lights. It was found that on the faulty unit the motor drive had basically ran to the end of its travel and jammed. Once "unwound" so to speak it centered itself when plugged back in. 2010 RRS, TDV8
Tue Feb 15 2022 7:20pm |
https://www.rrsport.co.uk/forum/topic58855.html
Tue Feb 15 2022 7:26pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
If you end up deciding to splash out on new lights my post here https://www.rrsport.co.uk/forum/topic53538.html might be of use to you. Robin
Wed Feb 16 2022 6:17am |
I don't remember seeing any orange light on the dash at start-up. So I'm pretty sure they are non AFS I've just put the Rangey in for a standard MOT and the mechanic is convinced this is an electrical problem as the lights wont communicate with his diagnostic tool. May need to do a bit of research myself between the difference in these lights. I'm hopeful its a simple fix but expecting to have to replace the lights. Just don't want to pay a fortune for an auto electrician if one is not needed |
Thu Feb 17 2022 4:29pm |
Standard lights don’t have a communication interface. So that’s why they won’t talk
Thu Feb 17 2022 6:27pm |
We had a customer drive 3 hours to us for MOT repairs, as the station failed it for Adaptive Self Levelling light not working
Thu Feb 17 2022 7:11pm |
