Home > Faults & Fixes > Suspension pump Temp Sensor |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 281 |
try island 4x4 they might have one |
Sun Jan 16 2022 5:39pm |
Mick1970 Member Since: 09 Mar 2020 Location: rotherham Posts: 8 |
Still looking for one of these if anyone can help. |
Thu Jan 27 2022 12:45pm |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 |
Is there anything like a s/n etc stamped/etched on the sensor?
Thu Jan 27 2022 2:27pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
Bit of a long shot,, but have you looked at these,,
Thu Jan 27 2022 2:41pm |
Just curious as to the problem with the sensor as I would think that it is the most reliable of all the bits attached to the compressor,,, apart from physical damage I thought it would outlast the compressor itself. If the issue was constant high temp warnings it could well be a fault with another part. If the compressor runs too long it will overheat,,,, they are only rated to run for a few minutes at a time I think. 2010 RRS, TDV8
Thu Jan 27 2022 3:03pm |
