Home > Technical > Iid tool help
jk3528
Iid tool help
So if you can get phone and rear camera on the sat nav screen by cutting a wire can you not just change the settings so you don’t have to cut anything?
Post #621084 Tue Jan 18 2022 9:54pm
No
What age car have you got
Post #621085 Tue Jan 18 2022 9:57pm
jk3528
O6 rrsport
Post #621094 Wed Jan 19 2022 11:04am
jk3528
Surely if the screen has the plugs in the back you should be able to use them
Post #621095 Wed Jan 19 2022 11:06am
Sadly not
There is a test screen where you can see a small picture.
Do you have a gap iid ?
Post #621097 Wed Jan 19 2022 1:07pm
jk3528
Yes
Post #621106 Wed Jan 19 2022 7:14pm
If you have a camera connected you can try this to see a mini picture. (select video inputs test)
&t=200s
OR upgrade to a facelift screen with later nav and easier camera input (gap IID required)
https://www.rrsport.co.uk/forum/topic55655.html
Post #621107 Wed Jan 19 2022 7:32pm
jk3528
Would I need a new screen or can I just change the programming
Post #621111 Wed Jan 19 2022 9:14pm
Option 1 program the Ccf to say rear cam fitted.
Unplug to yellow loom in the display to the front panel and connect camera.
This will give you an idea how the display will work.
Option 2. The link. Requires a replacement screen and other
Bits. Maybe £150
Post #621113 Wed Jan 19 2022 10:11pm
jk3528
If I changed to a later screen would that have the heater control?
Post #621148 Fri Jan 21 2022 10:00am
No.
But your can buy remote controlled fbh starters for £85-100
Or £300 for a one you can txt to start it
Post #621173 Fri Jan 21 2022 4:13pm
jk3528
Ok so now the Bluetooth has disappeared and when trying to reflash with iid tool it fails comes up with E4 fault code and then loads of faults in the future
Post #621236 Sun Jan 23 2022 8:47pm
