![]() | Home > Technical > Iid tool help |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
No
| jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75
O6 rrsport |
Surely if the screen has the plugs in the back you should be able to use them |
Sadly not
Yes |
If you have a camera connected you can try this to see a mini picture. (select video inputs test)
Would I need a new screen or can I just change the programming |
Option 1 program the Ccf to say rear cam fitted.
If I changed to a later screen would that have the heater control? |
No.
Ok so now the Bluetooth has disappeared and when trying to reflash with iid tool it fails comes up with E4 fault code and then loads of faults in the future |
| All times are GMT |
