![]() | Home > Technical > Disabling The Alarm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5144
First try pressing the remote lock button twice for a few days.
| Lynchy Member Since: 24 Oct 2021 Location: Newcastle Posts: 80
Yeah, i have started pressing twice as this disables the interior alarm (apparently), and if i only press it once, alarm goes off almost everytime.
Can’t remember.
Didnt know that got logged to be honest.
The autel ap200 (ideally white)
Where do you normally pick those up from? I can see a load on ebay but £79 |
This 1 OK?
Or that
Second one is more sensible.
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
Pressing the lock button once single locks,,,,, only locks the vehicle from outside entry ( perimetric). Pressing the lock button twice within 3 secs double locks ( locks from inside and outside) and also set the interior space alarm. You can disable the interior sensor and tilt sensor via the dash menu ( alarm sensors) but it is not permanent and will automatically revert to enabled again when you next open the car. 2010 RRS, TDV8
That’s in a facelift.
| Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 |
Its for life on the 1st manufacture you select, then, approx £19 per year for every additional manufacturer you add. Its a very cheap useful tool for scanning and clearing DTC's, oil change reset, steering reset EPB etc etc not sure it will help with your alarm though |
Have you got the white one ? |
So, ive got some embarrassing updates to my stress with the alarm system. Ive took down the hanging air freshener and only single lock the car now. No alarms in 2 nights so far........ |
| All times are GMT |
