Home > Maintenance & Modifications > I need help: LED bar Fitted with HighBeams
deceunincke
Belgium 2008 Range Rover Sport TDV8 HSE Bourneville
Hi all
I have fitted a LED lightbar on my '08 RRS tdv8 with a switch but I was wondering if someone paired this with their Highbeams?
I have a piggyback fuse ready to use, but can't really find that fuse. Or should I open upthe highbeam wire (no idea wich one) on the headlight and solder it together?
Anyone that can help me out? Would be nice to have them work in pair with my highbeams instead of a button.
Thanks!
Post #620545 Tue Jan 04 2022 3:40pm
Whoosh
What light bar did you buy and where did you get it .
Any pictures of it fitted as I’m thinking about fitting one .
Post #620548 Tue Jan 04 2022 5:05pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
Simple process of rerouting the positive trigger for your lights relay from the switch to the positive feed on one headlamp high beam. Place a Diode on the feed from the headlight high beam to prevent any backfeed into the central junction box which may trigger an error on your highbeam circuit.
Do not pull the 12V feed for your lamps straight off the headlight and use a Relay if you don't already have one. 2009 Range Rover Sport Supercharged
Post #620596 Wed Jan 05 2022 10:15pm
Abandito
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Easiest way would be to connect to back of one of your headlights and connect to high beam wire, think it’s 11 or 12 off memory, but easy enough to test with a meter.
Did mine this way and there are other posts about this topic too, some have wiring diagrams, but check the models carefully
Post #620677 Sat Jan 08 2022 7:42pm
Main Beam supply looks like Pin 10 Blue wire with Black tracer O/S headlight. N/S would be same Pin No. but Blue wire with Grey tracer.
Post #620679 Sat Jan 08 2022 9:31pm
deceunincke
Hi
Thanks all! Ill try to wire it that way.
Here’s a picture of the setup:
Post #620713 Sun Jan 09 2022 2:26pm
Pufftmw
Missing picture Sad
Post #620715 Sun Jan 09 2022 2:27pm
deceunincke
https://www.rrsport.co.uk/gallery/albums/u....6tdv8.jpg
Post #620716 Sun Jan 09 2022 2:29pm
Pufftmw
Very subtle Thumbs Up
Post #620717 Sun Jan 09 2022 2:31pm
deceunincke
Thanks!
I didn’t want to put it behind the grill because of the grill blocking some light.
I felt this would be a good position, and it’s kinda hidden.
Post #620718 Sun Jan 09 2022 2:33pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
That looks great i want to put one there aswell been looking at the black osram ones, Which light bar did you get?
Post #620736 Sun Jan 09 2022 11:30pm
deceunincke
I got the osram vx500 ledbar.
Shines really bright. You could go even bigger but make sure it fits. Or do 2 small ones.
I got the medium sized one.
Post #620738 Mon Jan 10 2022 12:41am
jases4x4
Thats the exact one i have lined up, it looks well made and i like osram. I have them for my daytime running lights very good quality they’re. I wanted to put one on the roof aswell but maybe this one in front bumper with be enough light?
When you connected to main beam did you just splice it into the red wire on the button switch? Im guesing you got the osram wiring harness aswell?
Post #620739 Mon Jan 10 2022 12:53am
Dave-t
Is there not a cooler behind there? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #620740 Mon Jan 10 2022 8:54am
jases4x4
Dave, Do you think the light bar would cause an issue to the cooler? I didnt think it would restrict any air flow tbh theres alot of space at both sides of the light?
Post #620747 Mon Jan 10 2022 10:28am
