Home > General (L494) > Anti Roll Bar arm replacement
Rowdie
Hiya
Does anyone know if a dealer replaced my Front Anti Roll Bars, due to worn bushes if the have to drain or reset the Hydraulic fluid for the ARC Ram at the front ?? of are they completely independent of each other ?
Thanks Rowdie
Post #620220 Thu Dec 23 2021 1:31pm
knwatkins
The ram is built into the ARB. If the bushes are worn, just the bushes should be replaced, not the whole ARB and no fluid is required to be drained, it's just the same as fitting bushes on a standard ARB. Kev
Post #620275 Sat Dec 25 2021 9:37pm
Oldandconfused
As Kev says, if the bar isn't leaking just have the bushes replaced. They may try to tell you that the bar is worn, but try replacing them with polybushes as they will last a lot longer than gen LR rubber ones. The access is very tight and there is a special tool to undo the bolts. I'm assuming you are using a independent LR specialist garage.
Post #620276 Sun Dec 26 2021 10:30am
