| RRSPORT.CO.UK | ||
|  | Home > General > Front sensors. |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      |
 Front sensors and rear are on according to GAPIID.Rears are working fine, My bumper is off on the front as they may have the sensors which aren't working, checking them out , all of them seem to be working . There are no fault codes. Could it be that the front sounder is not working and wherre is it positioned please .Cheers Pat | ||
|  Sun Dec 19 2021 7:45pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Sounder is part of the IPC
|  Sun Dec 19 2021 8:57pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | Indicator tick as in each of the four sensors , then yes. Orange light on the on off button steady . I will check the ignition bong tomorrow , battery off for fitting air condenser at the moment.
|  Mon Dec 20 2021 4:16pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | indicators being traffic direction indicators (that bmw drivers don't use)
|  Mon Dec 20 2021 5:48pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | Hmm, not quite getting that. What has the indicators got to do with the parking sensors.
|  Mon Dec 20 2021 10:25pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I would hazard a guess he means the same sounder is used for the direction indicators etc. as the parking sensors, so if it is working with the indicators there is nothing wrong with the sounder.
|  Mon Dec 20 2021 10:34pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | Hmm, not quite getting that. What has the indicators got to do with the parking sensors a dififferent sound I'm thinking..
|  Mon Dec 20 2021 10:37pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | OK I will check that , I know the front and rears are configured to work as a pair just now but rears only beep.
|  Tue Dec 21 2021 10:01pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | OK, I have no bongs when I open the door , or when indicators a used or when the key is in the ignition, so can I assume that that would be the reason why I cant hear the parking sensors are not audible? Again no faults for parking sensors a dash button is lit and not flashing. I can see there are videos to take the instrument cluster out , but would the sounder be repairable. | ||
|  Tue Jan 04 2022 1:57pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Here are some links to various other dash problems.
|  Wed Jan 12 2022 4:53pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | Thanks did a read, I have the cluster out know and some clown has been there already , white clips broken bar two and a botch soldering job has been done , probably without success , so will have look for a speaker to fit. I reckon the rear one bight be the same kind. Anyway will have to determine if it is broken first. | ||
|  Sun Jan 16 2022 5:03pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | Cluster off , speaker resoldered! Job done well not quite .
|  Mon Jan 17 2022 8:55pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Are you referring to the two at the bottom of the cluster ? if so they are 6mm by 20mm long.
|  Mon Jan 17 2022 9:48pm |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216      | YES , I am , the thread pitch is not normal , though, a lot course than 1.0 pitch . I may have to find L/R parts store , I robbed one off a lower part which was the same , but then realised there were another two of the same missing also..But yes they are the ones. | ||
|  Mon Jan 17 2022 10:24pm |
| Posting Rules
