Home > Technical > Loose battery connections
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Folks
The positive lead, when fully tightened, is loose on the terminal post.
I tried the cheap Censored post covers and threw them in the scrap.
Is there something better I can do, as I have a voltage drop overnight and the car refuses to start? Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #620109 Sun Dec 19 2021 12:52pm
All I can say is.
Loosen the bolt fully
Then push the terminal down fully. Get a hammer, and give it a light tap.
Do bolt up.
Post #620111 Sun Dec 19 2021 1:23pm
Peterh
Wrap the post in tin foil to increase the diameter or file the clamp so as to allow it to close more .
Post #620113 Sun Dec 19 2021 3:56pm
Dave B
Had the same issue, used a thin strip of metal to go half way round the battery terminal, opened the clamp up as suggested, and tapped it back over the terminal.
All good now.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #620115 Sun Dec 19 2021 4:19pm
gogsy1956
I'm with Andy,,, i've had the same trouble, if the terminal is not pushed as far down as possible it will not tighten around the battery post. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #620116 Sun Dec 19 2021 5:19pm
MartinsTDV8
I’ve ‘tapped it’ Whistle
I’ll try to wedge something inside before tightening it again, thanks folks. Previously owned 1999 Disco 2 TD5
Post #620138 Mon Dec 20 2021 10:22am
