![]() | Home > Technical > Car won't go into access mode when brakes are engaged |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
I really wouldn't take any notice of the horror stories, these are usually, well Numpty down the Pub said "blah blah blah" who has probably never even been in a Sport yet alone owned one.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
I would say it’s because the park brake is on and fairly normal.
Make absolutely no difference to mine if the park brake is on or off, it still goes into access mode.
When in perfect condition they do |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Sorry, but what a load of ball cocks. There is a thread somewhere about the compressor vent outlet becoming blocked which can cause this, cured by drilling a slightly bigger hole, this could be the beginning perhaps. As Col said, I don’t believe going up and down with brakes on is good engineering practice for the bushes and bearings, it just puts stresses through in the wrong direction and with resistance, far better to be rolling even if only very slightly. Joined the X5 45e club 1994 Defender 90 300 tdi |
Compressor vent outlet will be blocked,I had this problem with a friends sport a few years ago,i removed the filter fitted a new one which had a hole in it,the original didn’t have a hole as it was a early model sport,so I’m guessing LR worked this out & started fitting them with holes in.New filter was only about £8 iirc,I kept the old filter but drilled a hole in it just in case I got another sport in with same problem.
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
I concur - mine did the same with the compressor vent outlet blocked. Hopefully the same for the OP. There is no replacement for displacement - W O Bentley
Still seems a little odd that it only does it in park or with brakes applied as would have thought it had to exhaust air in either case, but this is land rover I guess. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
If it's not going in to access height with the brakes and / or park brake applied, there's a problem.
You could always remove the filter & see if that solves the problem,when my friends did it I removed the filter till the new one came,all that happens,is you can here the air coming out when adjusting the suspension. Andy.
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 ![]() ![]() ![]() |
i tried it again this evening. Had the car in park, and the handbrake on. Put it into access mode and it immediately raised up again. I then pressed down into access mode again and it worked? |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
My guess is that you need to have your suspension recalibrated. 07MY RRS TDV6
