Home > General (L494) > SOS SYSTEM - Limited Fuctuonality
Leachy2021
Morning!
I recently purchased a 2016 SVR
The battery has been low where sitting at dealership which is now due to be replaced.
The above fault has come up on the dash now with a yellow warning triangle.
Could this be due to the low main battery state?
Does it need to go to a main dealer to resolve the issue?
I purchased from a very good private dealership near Guildford.
Any help appreciated.
Thanks
Post #617368 Fri Sep 17 2021 7:04am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
I think this means either one of a few things: -
The internal battery backup in the tracker is depleted. You can change it yourself, bit of a job but do-able.
The system needs to be re-sync'd, you can do this by holding the white LR call button in the overhead console until it starts flashing to see if that manages to re-establish the connection.
I had syncing issues and after much messing around LR admitted that the problem was their end (after they denied this and told me to book the car in for diagnostics) and then it suddenly got better all on it's own! Assuming you have an active subscription it's worth contacting LR Customer Svcs and asking them to log the issue and they can pass it to the telematics division and remotely check it.
Hope this helps
Mike
Post #617404 Fri Sep 17 2021 5:25pm
Kitchenfitter
Have same issue
Would i be better to have an active subscription and if so which one ?
Post #618691 Wed Nov 03 2021 2:06pm
jimbg
https://www.landrover.co.uk/ownership/inco...index.html
What happens if I do not renew InControl Remote/Protect
If you do not renew InControl Remote or InControl Protect then the associated services will be disabled on your vehicle following the expiry of your subscription.
Will the SOS Emergency Call feature remain active?
If you do not renew your SOS Emergency Call service as part of your InControl Protect or Remote subscription, a limited emergency call service will remain active [for 10 years from the start of the warranty period ]. However, the Land Rover emergency service providers and / or Land Rover may no longer have access to your personal contact details (name, address, mobile number), so will only be able to contact or locate you via your vehicle, at the point of the emergency call. This information will remain available to emergency service providers provided your vehicle is associated with your InControl account. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #618697 Wed Nov 03 2021 2:39pm
Kitchenfitter
Will try the reset from white button
Is it worth subscription as i have a tracker and ghost fitted
Post #618710 Wed Nov 03 2021 10:54pm
Kitchenfitter
Hope this helps
Mike
Should it be illuminated as mine isn't
Started the car and message gone but trying to add it to my incontrol acc but no joy
Post #619038 Wed Nov 10 2021 2:38pm
jimbg
What subscription are you trying to add?
Has the car been "released" from the previous owner? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #619040 Wed Nov 10 2021 2:54pm
Kitchenfitter
Car has been released from previous owner but cant add to account and set up a subscription until car successfully added
Post #619054 Wed Nov 10 2021 8:03pm
jimbg
OK, the VIN is not being accepted? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #619065 Wed Nov 10 2021 11:15pm
Kitchenfitter
It accepts Vin and recognises the car and model the I go through the procedure where I press the left over head button for 10 seconds then wait a few minutes, that's when my phone should refedh and go on to next step but it doesnt I have waited over 30mins
Post #619071 Thu Nov 11 2021 5:18am
jimbg
I guess you have read this?
https://cdn.prod-row.jlrmotor.com/static/d..._en_GB.pdf
If it does not work then you will have to contact LR. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #619078 Thu Nov 11 2021 9:41am
Kitchenfitter
Seems be be the last fault.
When the car was still associated with previous owner the button was illuminated. I called the help centre and they said it prob is not illuminated now as previous owner has been removed.
Bloody nightmare this is - will try again later and fingers crossed
Post #619087 Thu Nov 11 2021 3:41pm
