Home > Technical > ACE ARE YOU THERE! |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
Just bought an RR sport hse and one the faults showing is the ace hydraulic pump isn't working , apparently its had a new one fitted and so where is this pump please. The reservoir is full , but I get a feeling the suspension is soft and bounces a bit when manoeuvring slowly and braking . I also rolls slightly when cornering , would this be an indication a why it throws a fault. |
Mon Oct 04 2021 2:05pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4785 |
what age car.
Mon Oct 04 2021 6:46pm |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Hi if a new pump was fitted was the system put through the bleeding process.I think there is a particular device that is used and a specific process.
Mon Oct 04 2021 6:54pm |
Apparently the system was bypassed , but I feel if I can understand something about it it would be beneficial, as it is quite soft, works better in Sport mode , handling that is , wishful thinking don't know .
Tue Oct 05 2021 8:59am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4333 |
What year, what engine, in what way has it been bypassed, is there a warning light on the dash? |
Tue Oct 05 2021 12:45pm |
57 Plate V8 Diesel, sorry I dont know enough about it , but I was told that a pipe was replaced and the system was disconnected. Seems like the seller doesn't want to help , I have mentioned it and that was his explanation . I reckon I got it at the price that suits. If maybe I can start at the beginning I will either delete altogether or sort.
Tue Oct 05 2021 7:40pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8837 |
Hmmm, there was a chap on the forum recently trying to sort out a TDV8 with a leaking system. Wanted to remove it and was generally told to forget it. Wasn't the same one, I wonder.
Wed Oct 06 2021 1:39pm |
Soundslike a familiar story I was told. The Garage that the seller used was a specialist , but I think in order to cut costs , the seller by passed the cost and sold it as it was . I am going to get more information on this one.
Fri Oct 08 2021 5:53pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1738 |
Member NAKS has a link https://www.mediafire.com/folder/bmioajx5v76k7/RR 2023 P440e SE Dynamic on order -cancelled
Fri Oct 08 2021 6:38pm |
I downloaded the file , and adobe , mainly to use a search facility to avoid endless scrolling . Its Still not helping , so can anyone give me pointers , not too savvy on files. |
Sat Oct 09 2021 7:17pm |
PM NAKS? 2023 P440e SE Dynamic on order -cancelled
Sat Oct 09 2021 9:28pm |
Is there a guide somewhere that I can check out the Dynamic response system to see what's needed to restore it and get it working gain , there are no leaks but I just get C1119-09(AF) Hydraulic Pressure- General failure information-component failure .Where do I start and is there a pathway . Perhaps the whole thing needs to go to manual I not sure. |
Sun Oct 17 2021 8:39pm |
This is painful to follow...
Sun Oct 17 2021 9:05pm |
Yeah , sorry its painfully for me as well , not knowing the system in car from the start , I've been sold a pup , not far from your area as well , mildly passed off! MY FAULT , JUST TRYING TO RECTIFY. Sorry for the shout !!
Sun Oct 17 2021 11:09pm |
