![]() | Home > Technical > ACE ARE YOU THERE! |
| alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216
Just bought an RR sport hse and one the faults showing is the ace hydraulic pump isn't working , apparently its had a new one fitted and so where is this pump please. The reservoir is full , but I get a feeling the suspension is soft and bounces a bit when manoeuvring slowly and braking . I also rolls slightly when cornering , would this be an indication a why it throws a fault. |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
what age car.
| Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 217
Hi if a new pump was fitted was the system put through the bleeding process.I think there is a particular device that is used and a specific process.
Apparently the system was bypassed , but I feel if I can understand something about it it would be beneficial, as it is quite soft, works better in Sport mode , handling that is , wishful thinking don't know .
What year, what engine, in what way has it been bypassed, is there a warning light on the dash? |
57 Plate V8 Diesel, sorry I dont know enough about it , but I was told that a pipe was replaced and the system was disconnected. Seems like the seller doesn't want to help , I have mentioned it and that was his explanation . I reckon I got it at the price that suits. If maybe I can start at the beginning I will either delete altogether or sort.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Hmmm, there was a chap on the forum recently trying to sort out a TDV8 with a leaking system. Wanted to remove it and was generally told to forget it. Wasn't the same one, I wonder.
Soundslike a familiar story I was told. The Garage that the seller used was a specialist , but I think in order to cut costs , the seller by passed the cost and sold it as it was . I am going to get more information on this one.
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924
Member NAKS has a link https://www.mediafire.com/folder/bmioajx5v76k7/RR 2026 P460e Autobiography on order
I downloaded the file , and adobe , mainly to use a search facility to avoid endless scrolling . Its Still not helping , so can anyone give me pointers , not too savvy on files. |
PM NAKS? 2026 P460e Autobiography on order
Is there a guide somewhere that I can check out the Dynamic response system to see what's needed to restore it and get it working gain , there are no leaks but I just get C1119-09(AF) Hydraulic Pressure- General failure information-component failure .Where do I start and is there a pathway . Perhaps the whole thing needs to go to manual I not sure. |
This is painful to follow...
Yeah , sorry its painfully for me as well , not knowing the system in car from the start , I've been sold a pup , not far from your area as well , mildly passed off! MY FAULT , JUST TRYING TO RECTIFY. Sorry for the shout !!
| All times are GMT |
