![]() | Home > Maintenance & Modifications > Gearbox leak monitoring/dash alert |
HappyHammer Member Since: 24 Jan 2017 Location: Essex Posts: 59 ![]() ![]() ![]() |
Hi guys,
There is no way of monitoring transmission oil level with a warning on the dash/ instrument panel, I believe the only way to check the oil level is via the level plug on the side of the transmission, probably find the only sign you get when driving with a transmission leaking oil, is a transmission overheat warning or losing drive when oil gets low enough. If you are certain it is transmission oil leaking I suggest you get it fixed now before it develops in to something more expensive.
NeilN Member Since: 29 May 2008 Location: Durban Posts: 21 ![]() ![]() ![]() |
Did you manage to solve the problem?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
The electric connector sleeve is the common problem |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Had the same problem with mine, the gearbox sump was found to be leaking new sump pan fitted ( part no. DA2142 gearbox filter sump conversion kit ) the kit was priced at £70.91 + VAT when I had it replaced last year in August, pleased to confirm no more oil on the garage floor. |
