![]() | Home > Detailing & Car Cleaning > Black parts... advice needed |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
For the pullar trim I use quick detailer because mine isn't faded. If yours is faded it might benefit from a MOP to take the fading off, then keep on top of it. The scuttle is typically a poor choice of plastic. It goes grey and anything you put on it is only going to be temporary. I used autoglym bumper/rubber treatment, some use Gtechic G4 i think. There is a thread either on here or the D3 site where someone took it off and painted it, which I imagine should last. |
My black trim is still black, but my skuttle panel was greyer than a grey thing. DrRob put me onto this Gtech G4 stuff that O&C mentions above. This is magical stuff, a bit pricey if you see the size of the bottle. You don’t need much and a small bit goes along way. 100% recommend it. 2006 2.7 TDV6 HSE in Cairns Blue. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9081 ![]() ![]() ![]() |
If you do a search on here, someone actually recommended peanut butter for the black scuttle panel. I would guess it's the oil in it that makes the plastic look black again. No idea how good it is at keeping the plastic black, however. 2012 SDV6 - it's missing a couple of cylinders
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Crunchy or smooth? |
Have a read and see for yourself:
I sprayed mine which resulted in zero maintenance thereafter...
That's the thread I meant. Good job.
Thanks. If anyone decides to do this, whilst you have the scuttle off, it's also worth making a little water deflector for the air intake to avoid soggy carpets in the future...
Pitcher Member Since: 07 Feb 2022 Location: Birmingham ish Posts: 20 ![]() ![]() |
Meguiars ultimate black, it is a white cream, although didn't streak, it left run marks on the paint underneath after rain, wiped away quite easily though.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
#2 for Maguiars Ultimate black, works a treat on all black pillar trims and grey lower trims and lasts well. Wouldn’t work on the scuttle trim so I removed and painted mine.
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 214 ![]() ![]() ![]() |
Hi I had the same issue with the scuttle panel and used a product called Ceratrim . It worked wonders on it and brought a colour back to it.Cant rate this stuff high enough. |
How durable is the Ceratrim?
Hi it’s great I just go over it every 3 months approx |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 928 ![]() ![]() |
Gtechniq C4 Permanent Trim Restorer
