Home > In Car Electronics > Resting Heart Rate
Pufftmw
Resting Heart Rate
I've just fitted a remote battery monitor to my battery (of course) and its showing 11.97V whilst not doing anything. Seems fine when you start up the car but quickly goes to that when turned off.
Battery goosed?
Post #617628 Thu Sep 23 2021 12:00pm
Scrumpy
Are you checking soon after you turn the car off? I think it takes about 10 minutes for all the systems to shut down and go into standby.
Try checking after 30 minutes?
I might be wrong. 2016 RRS SVR Estoril Blue
Post #617629 Thu Sep 23 2021 12:11pm
Pufftmw
Good point. Checked just now and its 12.03 and flickering between "Discharged" and "Fully Discharged"
But its still enough to start the engine currently...
Post #617630 Thu Sep 23 2021 1:07pm
RRT
Based on my boat's batteries - at rest they should rest at around 12.8v MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #617631 Thu Sep 23 2021 1:19pm
gogsy1956
12.03v is too low,, it's bordering on letting you down 12.6V is a fully charged battery. I have a monitor on mine, the battery is quite new and it never drops below 12.4 ( unless cranking of course). I even checked it against a good quality multimeter just to make sure it was a true readingj. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #617632 Thu Sep 23 2021 1:28pm
jimbg
Posted this many times before! Rolling with laughter
 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #617634 Thu Sep 23 2021 3:17pm
Pufftmw
OK, so its fubar'd then
Post #617650 Thu Sep 23 2021 10:26pm
How long do you run the engine when it is running? If you're doing shorter journeys, the battery won't get charged up.
I'd put it on a ctek for a day, leave it a day and then see what it's sitting at. Start the engine, do a typical journey, park it and check after 24 hours.
Why leaving it between charging/running and checking? Because you get surface charge which gives a false high reading. Leaving it for 24 hours allows this surface charge to dissipate and you get a truer reading. 2012 SDV6 - it's missing a couple of cylinders
Post #617653 Fri Sep 24 2021 12:14am
Pufftmw
I think its stuffed as I had I charged it fully on Monday and on Tuesday I did 2 1/2 hour runs and on Thursday its as it was in this thread.
Post #617661 Fri Sep 24 2021 12:20pm
jimbg
The trouble with batteries is that they will start now on a reasonable weather day, but come winter that is when is will let you down.
I presume that the cranking amps are down as well and when you need them in the winter they will not be there? Big Cry 2026 P460e Autobiography on order
2006 HSE
Post #617662 Fri Sep 24 2021 12:24pm
Ah, that does sound like it's FUBAR'd. What's the alternator's output like? 2012 SDV6 - it's missing a couple of cylinders
Post #617663 Fri Sep 24 2021 12:27pm
Pufftmw
11.97 today (24 hours+ later)
When its running, its 14.x
Post #617669 Fri Sep 24 2021 7:25pm
