![]() | Home > Faults & Fixes > Handbrake loud squeeling |
DarrenRRS Member Since: 25 Aug 2021 Location: Glasgow Posts: 12 ![]() ![]() |
Hi Guys
Hi Scrumpy,
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
You may be lucky and not have damaged the discs, lets hope so if they've just been done.
Thanks Scrumpy, i haven't been using it. I have sent a few messages to RR specialists within my area. Not just a mechanic, see what they say |
I don't get how the discs, pads and shoes are damaged through a broken EPB actuator?
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 953 ![]() ![]() ![]() |
I completely agree with scrumpy,, he's right on the money with what he says,,, I know as I've also even down that road. You say the brakeswere done 8 months ago,,, depends what that actually consisted of, if it was a case of new pads chances are the parking brake wasn't touched. Big enemy of the EPB is poorly serviced shoes,, they need to be cleaned and adjusted correctly at every service to keep them working,, which involves removing the discs. One reason they get overlooked. 2010 RRS, TDV8
Hi Gogsy
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
You may well get away with a strip and adjust if it's not been ignored (fingers crossed).
Don't go for the third attempt,, |
Agreed. It's best to not use the EPB until it's fixed.
Thanks guys i have a friend who is a mechanic for a dealership who's states he can strip this and have a look as stated above. So may have a go at that and potentially save £££ |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
If it's squealing then it's likely that a strip and clean of the rear brakes will sort it. May need new hand brake linings / disc too. But unlikely to be the EPB module itself. 2012 SDV6 - it's missing a couple of cylinders
[quote="knwatkins"]I don't get how the discs, pads and shoes are damaged through a broken EPB actuator?
Ouch, that's not good. Glad you've got it sorted Scrumpy. Kev
