![]() | Home > General > Anyone Fitted A Ctek Comfort Indicator Panel? |
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1058
If so where please?
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
I think someone may have made a metal bracket, to mount behind the grill.
Actually
| Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 100
Yes I also had a look at one of these.
| Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 354
Ok sont mean to sound thick lol what is this for ? |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
It gives a readout of battery state so you know whether to connect up your battery charger or not. Kev
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
The part with the indicator lights hooks up permanently to your battery which then makes it easy to just plug the Ctek charger into without having to faff about with connecting it to the battery each time. I have one fitted but only to the battery box so I still need to open the bonnet to use it. However the traffic light system is more of a pain than anything else. I couldn't work out why, with a new battery it was continuously flashing orange or red until someone explained that when you lock the car, all the ECU's are still running for a few minutes and this puts a drain on the battery. I guess it's different if you can see the lights through the grill as they will eventually go green! 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
| Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189
Wanted to ask the same... So do other peeps have problems with the battery continually going flat??? |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
If used daily they appear to be fine, but if left unused the do seem to drain down over time. I have the basic non mounting comfort connector and it just tucks away under the back edge of the bonnet out of sight when not being used, can still see traffic light if required but don't really take any notice of them. Also means can plug or un-plug without unlocking the car or bending down which is a bonus at my age. |
I actually have the 13pin tow plug connector for my Ctek, so can just plug it in there without opening the car but I was wanting the visual indicator to know when to do it! My car spends a reasonable amount of time doing nothing and it does sometimes drain down, so something that I can glance at as I go by was the idea.
Could try one of the bm2 type battery monitors and use the app on your phone to check charge state, they are quite accurate.
I forgot I had a CTEK charger from my old Audi S2, so have ordered one of these today
Cheers |
I prefer putting it in the boot. Depends where you park really
| All times are GMT |
