![]() | Home > General > Handbrake Stuck. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
So the release loop didn't work when you pulled it? That's surprising. 2012 SDV6 - it's missing a couple of cylinders
Sheedy773 Member Since: 02 May 2021 Location: Castleford Posts: 27 ![]() ![]() |
Unfortunately not. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I had this with mine. Assuming you accessed the release loop in the centre console, it needs a REALLY hard pull to get it to release. i took a 18" length of steel rod and bent a hook on one end and loop on the other through which I put a length of 1.1/2" timber. For control, my son and I, one each side of the transmission, pulled upwards and it released. Others have used a carabiner through the loop with some rope to extend the release.
Accuator (sp?) Fault.
woodsie Member Since: 23 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
Mine stuck on about a month ago luckily only about a mile from my indie so was able to drive there.
For the reference of others, LR thought of this and designed the jacking handle according. Take the two parts of the jacking handle - there is a loop at one end and a hole at the other, thread the second part through the hole and you have a big T with a hook on the end. Catch the loop with the hook and pull up using the big T you've formed. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5104 ![]() ![]() ![]() |
L/R are even kind enough to tell you, you need to exert 200N or 45Lbf of force to release it as well. |
So,
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
Cost me about £1200 when mine siezed, even with cables cut still wouldn't release,,, new disc's, pads, shoes and module needed. 2010 RRS, TDV8
Dropped off today.
If I understand correctly pulling the emergency release cable just disengages a pawl in the actuator to release pressure on the cables, no amount of pulling will release the handbrake shoes if the problem is inside the drum i.e. as mentioned linings coming a drift and jamming. If cutting the cables did not release it the problem must be inside a drum or both so, I would ask the question was there ever a issue with either the cables or module in the first place, and could it be salvaged by just replacing the now cut cables and save some costs. However I could well be wrong in my thinking.
That's my thoughts on it too, Col. If the issue is in the brake hub rather than the EPB box, then replacing the cut cables and sorting the brake linings should be entirely possible. The cables are replaceable items, after all, and at a fraction of the cost of the whole EPB system. A couple of hundred quid for the cables and then new rear linings (assuming the disc hub unit isn't damaged) ought to be a lot less than the quoted £1200.
I've seen a video where a bloke strips down an UPB module to replace a plastic cog which had stripped teeth. I can't recall if the stripped teeth had caused the jamming or the jamming had stripped the teeth. The point I'm making is if there is damage inside the module then changing the cables alone won't cure the problem.
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I'm going through the same thing at the moment.
