![]() | Home > General > Handbrake Stuck. |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
That's a good point!
Sheedy773 Member Since: 02 May 2021 Location: Castleford Posts: 27 ![]() ![]() |
In fairness, I do trust these gents.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
So did the park brake release after the original outfit cut the cables?
Yes, that does make sense. He's referring to the worm gear within the EPB actuator. It's the bit that drives the cables that the brake shoes connect to. If the gears are stripped within the actuator, you don't need a new actuator (£££). You can buy a rebuild kit - part number DA9223. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
If the brake linings are physically jammed inside the brake drum, the actuator could be released and you'd still have no movement. You mention that the cables were cut and it still wouldn't move - that suggests the problem is at the brake end of the system, not the module. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
