Home > Maintenance & Modifications > Lower Control arms
Phil2k
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Lower Control arms
Steering has started to shake a little at certain speeds and im getting a knock when i jab the brakes at low speed so im guessing its time to replace the lower control arms.
Local garage have said if i get the parts they will fit for cash.
Looked online and found prices ranging from £120 a pair to over £250 a side. Can someone recommend a set for me please.
Cars a late 2012 AB
Also going to get them to do the sway bar bushes whilst its on the ramp
Thanks
Post #617207 Sun Sep 12 2021 6:07pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi just had both my lower arms replaced make sure they replace the bolts and mark the concentric bolt outer shim to make sure the alignment is back to as it was.Mind it’s always worth getting the alignmen checked and set back up also.Got the work completed by my local 4x4 Land Rover Indi. Thumbs Up a
Post #617209 Sun Sep 12 2021 6:28pm
Phil2k
What was the cost if you dont mind me asking?
Post #617217 Sun Sep 12 2021 10:13pm
Fitted these Meyle one's on mine, good quality and fitted spot on with no problems. Personal opinion any at £120.00 a pair = cheap and nasty.
https://www.advancedfactors.co.uk/kit685hd...9798-p.asp
Post #617218 Sun Sep 12 2021 10:34pm
Farmer Chalk
And don’t buy cheap bolts either….must go oem….they are torqued up tight and cheap ones are like cheese…
Only use the garage if they know what they are doing.. the bolts can only be tightened when there is a load on them…I.e car sitting on its wheels… four wheel alignment afterwards is a must!
Post #617225 Mon Sep 13 2021 8:32am
Dropped by TWT because I felt a slight pull to the left.
They showed me that the front lower control arms, which were replaced in June 2022, have excessive front-back movement.
Considering that since they were fitted 487 days ago, I have spent 183 days overseas + I don't drive it daily, that is really dismal quality from LR.
workshop has filed a parts claim with LR Stellenbosch for replacement parts. --
Post #636857 Thu Oct 26 2023 6:09pm
^ LR stealer refuses the warranty claim Censored --
Post #636980 Tue Oct 31 2023 2:52pm
