Home > In Car Electronics > OBD II Constant power cable
gavcav
Has anyone tried one of these to power a dash cam? Plugs into the OBD II Port and selectable to allow constant power or power for 10 mins after the ignition is switched off. It seems a much simpler method than piggy backing a fuse etc to hardwire a dash cam?
https://www.amazon.co.uk/Garmin-010-12530-...&psc=1
Post #617020 Sun Sep 05 2021 10:28am
The only down side is if you have big feet you may kick it.
It is silm though
Post #617024 Sun Sep 05 2021 11:39am
Tyrefitter
I’ve just fitted similar to my ford ranger powering my Thinkware 770 dashcam,,I relocated the obd which is also a good idea if anyone tries stealing car & cannot find obd to plug into Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #617027 Sun Sep 05 2021 1:37pm
Autobiography1969
Is the OBD permanent live when the car is off??
Or can it be made to be?
L320 2012.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #617029 Sun Sep 05 2021 3:39pm
Tyrefitter
Certain pins are,all obd’s are wired the same.The plug into the obd I have is from Thinkware so is wired for ignition live & constant for the parking mode. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #617031 Sun Sep 05 2021 3:58pm
gavcav
Tyrefitter, thanks for your reply..so are you using the Thinkware OBD II permanently connected to your car? and does it have some kind of electrical circuit protection?
Post #617053 Mon Sep 06 2021 5:43pm
gavcav
Autobiography1969, thanks for your reply. I believe the switch on the adapter can be selected for permanent power (24hrs) or 10 mins after ignition has been off.
Post #617054 Mon Sep 06 2021 5:45pm
Tyrefitter
It stays connected all the time. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #617056 Mon Sep 06 2021 6:38pm
gavcav
Autobiography1969 heres a good link:https:
//www.thedashcamstore.com/garmin-obd-ii-constant-power-parking-mode-cable/
Just found out from Garmin it can be selected to supply power for 10 mins after igntion off, 24 hrs after ignition off or be permanent power supply.
Going to ask my indy L/R chap what he thinks about using the OBD port..think i'll know he's answer!
Post #617057 Mon Sep 06 2021 6:45pm
espy
United Kingdom 2013 Range Rover Sport Supercharged Santorini Black
I Got one of these with my Garmin dashcam 57 and it seems to work exactly as described: shuts off power after 10 mins (with a 24 hour option) It also completely powers down if the battery voltage gets too low.
To me, this is definitely better than messing with piggyback fuses etc.
I havent had any ptoblems hitting it with my legs - it dowsnt seem to stick out much. 2020 SVR Santorini Black
2016 SVR Santorini Black
2009 SC Stornoway Grey
2005 SC Zermatt Silver
1999 P38
1990 Overfinch Classic
Post #617059 Mon Sep 06 2021 7:48pm
gavcav
Thanks espy, good to know..thanks for taking the time to reply.
Post #617075 Wed Sep 08 2021 12:51pm
