Home > In Car Electronics > OBD II Constant power cable |
gavcav Member Since: 07 Feb 2020 Location: Leeds Posts: 18 |
Has anyone tried one of these to power a dash cam? Plugs into the OBD II Port and selectable to allow constant power or power for 10 mins after the ignition is switched off. It seems a much simpler method than piggy backing a fuse etc to hardwire a dash cam?
Sun Sep 05 2021 10:28am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
The only down side is if you have big feet you may kick it.
Sun Sep 05 2021 11:39am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
Is the OBD permanent live when the car is off??
Sun Sep 05 2021 3:39pm |
Certain pins are,all obd’s are wired the same.The plug into the obd I have is from Thinkware so is wired for ignition live & constant for the parking mode. Andy.
Sun Sep 05 2021 3:58pm |
Tyrefitter, thanks for your reply..so are you using the Thinkware OBD II permanently connected to your car? and does it have some kind of electrical circuit protection? |
Mon Sep 06 2021 5:43pm |
Autobiography1969, thanks for your reply. I believe the switch on the adapter can be selected for permanent power (24hrs) or 10 mins after ignition has been off. |
Mon Sep 06 2021 5:45pm |
It stays connected all the time. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
Mon Sep 06 2021 6:38pm |
Autobiography1969 heres a good link:https:
Mon Sep 06 2021 6:45pm |
espy Member Since: 14 Jun 2010 Location: Essex Posts: 36 |
I Got one of these with my Garmin dashcam 57 and it seems to work exactly as described: shuts off power after 10 mins (with a 24 hour option) It also completely powers down if the battery voltage gets too low.
Mon Sep 06 2021 7:48pm |
Thanks espy, good to know..thanks for taking the time to reply. |
Wed Sep 08 2021 12:51pm |
