![]() | Home > General (L494) > Aircon System Cleanse |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 205 ![]() ![]() ![]() |
Seem to recall there was a TSB for "moldy smell from aircon" on MY14-15, due to insufficient drains from the main unit. Dash out job to sort, hence not many people wanted that done and hence put up with it. |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
Yes thats what I heard too not sure if I trust them to remove the dash without putting it back with a rattle or squeak! So was looking at alternatives, Her indoors car seem to semll ok but there is a bit of a scent left behind but its not that bad, just owndered if there was anything else out there that didnt leave a smell behind as such.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 953 ![]() ![]() ![]() |
Never been in a car yet that doesn't have a bit of " AC smell " during operation. Bite the bullet and use an aerosol cleaner ( Halfords) on a regular basis and also make a habit of turning the AC on most every day for a short while,, no matter what the weather. 2010 RRS, TDV8
Yeah thats true my merc had a similar start up smell but dont rmeber my last sport having it so much. I dont hardly use this one so thought the bom method to be the simplest just owndered if anyone had a good experience with a particular brand that doesnt make the car smell like a tarta handbag after! If a jobs worth doing, get a someone who knows what they are doing to do it!
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
I wonder if the secret to odourless aircon is always leave it on? I've done this for years and haven't had any problems or bad smells. I just set a temperature, 21.5 C and leave it on auto, never touch it apart from severe cold and frost.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1886 ![]() ![]() |
It is a long time since we had simple air conditioning functions, climate control has been around a long time and should be left on.
Mine is always on I dont see the point in turning it off for the minimal amount it saves also AC systems like to be used, climate control I think uses it anyway so its quite difficult to turn it off. If a jobs worth doing, get a someone who knows what they are doing to do it!
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
Did you find anything to cure the smell mine as just started smelling. |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
Not a Sport however might be worth a shot |
So I tried a STP one from Halford or amazon (tested one in the missus car first! Smelt ok to be fair I didnt want a perfume smell and have never been keen on car air freshners, this one seemed to works for a bit, I took the filter out and then let it go and then left the windows open for the rest of the day to let it breath. And for the next few days I could smell the scent from it but it did slowly go away. I then started to try turning the heat on just before I got out of the car to see if drying the ducts out might help too.
Coleman19d Member Since: 08 Jul 2021 Location: North Lincolnshire Posts: 7 ![]() ![]() ![]() |
My 2 products I use.
