Home > In Car Electronics > Reverse camera/parking sensor visuals not working
RRS2015Fujiwhite
United Kingdom 2013 Range Rover Sport SDV6 HSE Fuji White
Hi Everyone
(65 plate RRS - 3.0 SDV6).
I’ve recently bought my RRS - and strangely the rear camera doesn’t work at all and neither do the parking sensor visuals pop up.
The parking sensors themselves do work however and I get the audible alerts.
The menu options are there for the camera but nothing happens at all when you the tap the camera button on the infotainment system.
I’ve tried changing the fuse for the rear camera (2amp) but still no luck. I’ve also changed the fuse for the parking sensors (10amp) to no avail.
Any advice from anyone who’s faced similar?
Post #615346 Thu Jul 01 2021 1:48pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
I suspect you have 1 faulty sensor, can you download the utlrasonic app on your phone and test them each to see if one is bad?
Post #615352 Thu Jul 01 2021 3:11pm
RRS2015Fujiwhite
Ah okay that’s interesting - let me try that out and see where I get. Thank you!
Post #615354 Thu Jul 01 2021 3:21pm
RRS2015Fujiwhite
I gave the ultra sound detector app a try but no luck unfortunately. It doesn’t seem to detect anything.
I did check each sensor one by one by however by waving something in front of each one individually and they all work.
Incidentally however the rear sensors were quite laggy and took a while to respond compared to the front ones…..
Post #615370 Fri Jul 02 2021 10:20am
what is the correct app to use anyway ?
Post #615374 Fri Jul 02 2021 10:53am
RRS2015Fujiwhite
I used something called ‘UltraSound Detector’ by Sergio Gudkov
Post #615375 Fri Jul 02 2021 10:57am
Brit Plumber
Go into diagnostic mode to see if you get an image from the camera. The camera is transmitting all of the time, selecting reverse only switches the screen to camera rather than switching the camera on. If it doesn’t work in diagnostic mode, you either have a failed camera or a bad co-ax. If there was no power I think you would get a dash warning. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #615657 Mon Jul 12 2021 3:14am
Crraigymmmmm
I think any of the ultrasound apps work, I tried a few on the mrs Exeo when diaging my system.
On the camera in the Valet mode mine has a green line but works fine when in reverse???
Post #615662 Mon Jul 12 2021 10:58am
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Ok so camera, different age although I am fitting one with a separate monitor.
Post #620253 Fri Dec 24 2021 11:25am
