![]() | Home > In Car Electronics > Reverse camera/parking sensor visuals not working |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
I suspect you have 1 faulty sensor, can you download the utlrasonic app on your phone and test them each to see if one is bad? |
RRS2015Fujiwhite Member Since: 10 Jun 2021 Location: London Posts: 4 ![]() ![]() ![]() |
Ah okay that’s interesting - let me try that out and see where I get. Thank you! |
I gave the ultra sound detector app a try but no luck unfortunately. It doesn’t seem to detect anything.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5121 ![]() ![]() ![]() |
what is the correct app to use anyway ? |
I used something called ‘UltraSound Detector’ by Sergio Gudkov |
Go into diagnostic mode to see if you get an image from the camera. The camera is transmitting all of the time, selecting reverse only switches the screen to camera rather than switching the camera on. If it doesn’t work in diagnostic mode, you either have a failed camera or a bad co-ax. If there was no power I think you would get a dash warning. 2019 5.0 SC SVA (Current)
I think any of the ultrasound apps work, I tried a few on the mrs Exeo when diaging my system.
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 216 ![]() ![]() ![]() |
Ok so camera, different age although I am fitting one with a separate monitor. |
