![]() | Home > General (L494) > Retofit Fail on RRS MY16 HSE |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
I reckon you might have a switch for the later 2017 on models then
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
This is the original switch in the car
The part I bought for mine which is for the later models anyway cam with a little harness cable
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 99 ![]() ![]() ![]() |
From the information that 'pjbracer1' and I have now discovered, you have the correct rear view mirror for a MY2016 vehicle. The 'G' indicates a MY2015/16 fitment "Every Day is a School Day"
12554 Member Since: 23 Jan 2018 Location: Stockholm Posts: 4 ![]() ![]() |
Change over to this position on the grey plug, then it will work. ![]() ![]() RRS 2016 TDV6 DII 1999 V8 |
machintruck Member Since: 12 Aug 2020 Location: Perpignant Posts: 9 ![]() ![]() ![]() |
Hello
Good work chap glad you now have it sorted, the bus is different on those models cars as you hence the upgraded items on the 2016 on, like the AC unit haveing the heated seats imbedded in the temp controls again like they used to be on the L320!
Thank you pjbracer1 your comments are always highly appreciated.
If you are gonna do blindspot might be worth thinking of revers traffic detection too! and if you have to take the rear bumper off mght as will rerto fit the side parking sensors on the reaer lower quarters so you can can try and get perpendiuclar park working. mine has parallel park and the only thing it needs for perpendicular is the side sensors but its a bumper off to fit them and I can be bothered!
ACC retrofit :
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 45 ![]() ![]() |
Hi all i am looking to retro fit TSR to my 2014 RRS, does anyone know if you still need to change the mirror if you have high beam assist and acc already?
Yes read this post If a jobs worth doing, get a someone who knows what they are doing to do it!
Ventiletor Member Since: 11 Apr 2025 Location: Randolph Posts: 2 ![]() ![]() ![]() |
Try to do rear mirror retrofit using SDD JRL and can’t proceed with new module installation option. Is the anyone chance to do ecu update or reprogram using SDD?
Are you sure the UK one doesn't work Im pretty sure the TSR is not based on the type of sign it can see it just reads the numbers. If it cant see a sign it will often display speeds based on the satnav.
