Home > General (L494) > Retofit Fail on RRS MY16 HSE |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 395 |
I reckon you might have a switch for the later 2017 on models then
Thu Feb 25 2021 3:05pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
This is the original switch in the car
Fri Feb 26 2021 10:59am |
The part I bought for mine which is for the later models anyway cam with a little harness cable
Fri Feb 26 2021 2:52pm |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 72 |
From the information that 'pjbracer1' and I have now discovered, you have the correct rear view mirror for a MY2016 vehicle. The 'G' indicates a MY2015/16 fitment "Every Day is a School Day"
Tue Mar 02 2021 9:20am |
12554 Member Since: 23 Jan 2018 Location: Stockholm Posts: 4 |
Change over to this position on the grey plug, then it will work. ****************** RRS 2016 TDV6 DII 1999 V8 |
Tue Mar 09 2021 2:44pm |
machintruck Member Since: 12 Aug 2020 Location: Perpignant Posts: 8 |
Hello
Sun May 23 2021 11:10am |
Good work chap glad you now have it sorted, the bus is different on those models cars as you hence the upgraded items on the 2016 on, like the AC unit haveing the heated seats imbedded in the temp controls again like they used to be on the L320!
Sun May 23 2021 11:24am |
Thank you pjbracer1 your comments are always highly appreciated.
Sun May 23 2021 12:33pm |
If you are gonna do blindspot might be worth thinking of revers traffic detection too! and if you have to take the rear bumper off mght as will rerto fit the side parking sensors on the reaer lower quarters so you can can try and get perpendiuclar park working. mine has parallel park and the only thing it needs for perpendicular is the side sensors but its a bumper off to fit them and I can be bothered!
Sun May 23 2021 1:41pm |
ACC retrofit :
Fri May 28 2021 6:27am |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 32 |
Hi all i am looking to retro fit TSR to my 2014 RRS, does anyone know if you still need to change the mirror if you have high beam assist and acc already?
Sun Jul 23 2023 10:23am |
Yes read this post If a jobs worth doing, get a someone who knows what they are doing to do it!
Sun Jul 23 2023 11:05am |
