![]() | Home > General > 2012 sdv6 brakes |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
It must just be a personal taste thing. I drive rapidly and have never had an issue. 2012 SDV6 HSE. Bear in mind the sheer weight of the car. I tend to drop it in S mode if in a proper hurry as the engine breaking mode is significantly better than in D mode, or occasionally use the paddles. |
| RRSSDDUB Member Since: 31 Mar 2021 Location: NE Posts: 28
thanks but my other car is an old disco 2 so still quite heavy |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
you could check to see if there is oil in the servo vac pipe like the old models got.
| Sparkey Member Since: 03 Feb 2021 Location: Yorkshire Posts: 24
The brakes on the SDV6 are not great to be fair,
nope not brembo just look like standard 4 pots |
yes i have seen this upgrade but dont really want to spend £1000....the TDV8 upgrade may be an option any idea which ones fit or is it all TDV8 with Brembo ? |
| All times are GMT |
