Home > General (L494) > Jacking with Trolley Jack
martrrs
Hi, I'm replacing all 4 wheels on my RRS so I've bought an SGS 3T trolley jack (as recommended in another post I found). Can I use the normal jacking points with this trolly jack? They look like solid steel to my untrained eye!
Thanks in advance.
Post #612638 Wed Apr 14 2021 3:18pm
Any good to you? From the workshop manual.
 2012 SDV6 - it's missing a couple of cylinders
Post #612641 Wed Apr 14 2021 3:53pm
martrrs
Perfect - Thanks
I'd seen mention in other posts of lifting from the suspension arms but looking underneath I couldn't really be sure about where the jack should go to do this.
Will I need a pad or something to avoid metal on metal contact using the jacking point?
Thank you.
Post #612643 Wed Apr 14 2021 3:58pm
knwatkins
A pad or suitable block of wood would be good to spread the load and avoid superficial damage to the jack pad to your shiny new jack. Kev
Post #612651 Wed Apr 14 2021 10:08pm
riverblanche
Ice hockey Pucks can work well as a jack pad as well
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #612664 Thu Apr 15 2021 10:28am
rrsfan
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I will have fixed side steps on my car. Can anyone tell me if I can still use a jack to lift the car or will the side steps come in the way ?
Post #612692 Fri Apr 16 2021 2:20pm
riverblanche
ours had fixed side steps (2016) and dont remember any issue with jacking points obstructed.
although I used to jack under the suspension arms anyway.
Post #612698 Fri Apr 16 2021 5:34pm
