![]() | Home > General > rear parking sensors not working |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
| Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184
Not sure if it helps but this week I had my RRS fixed. One sensor on the front bumper failing took out front and rear sensors plus the reversing camera. Front O/S sensor replaced and everything instantly works again. There is no replacement for displacement - W O Bentley
| martinh61 Member Since: 26 Mar 2021 Location: tamworth Posts: 2
could be a sensor, camera still works fine. the question is if one rear sensor fails why does it say the other three have failed too?? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143
Could be a short on one sensor or wiring chaff on bumper |
| Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394
have a listen if there ticking |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
My sensors have started playing up again. I am occasionally getting the high pitched warning sound. Not the same symptoms as you as they still work sometimes. I will have to investigate as soon as the weather gets a bit warmer and initially I will start at the rears because I am very suspicious of the way LR routed the cabling. Andy K's comment about chafing is high on my list of possible causes.
| TrafficMan Member Since: 01 Nov 2020 Location: Nottingham Posts: 8
Can the front offside corner sensor be replaced without taking the whole bumper off ?? |
They took my bumper off to replace the front offside sensor. Only cost me £250 for the diagnostics, part and fitting. There is no replacement for displacement - W O Bentley
| All times are GMT |
