Home > General > rear parking sensors not working
martinh61
England 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
hi all new to the forum
diagnostic check shows all rear parking sensors not working(front sensors ok))surely all of them wouldn't of failed? does that indicate wiring fault? rather than sensor fault? look forward to all your experiences of this issue and the likely problem/fix
Post #611944 Fri Mar 26 2021 5:27pm
riverblanche
Seem to remember a thread on this in the past Confused
Have you had a go with the "Search" button in the top title bar yet Question
First port of call for most stuff
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #611945 Fri Mar 26 2021 5:40pm
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Not sure if it helps but this week I had my RRS fixed. One sensor on the front bumper failing took out front and rear sensors plus the reversing camera. Front O/S sensor replaced and everything instantly works again. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #611946 Fri Mar 26 2021 5:43pm
martinh61
could be a sensor, camera still works fine. the question is if one rear sensor fails why does it say the other three have failed too??
Post #611948 Fri Mar 26 2021 5:51pm
Could be a short on one sensor or wiring chaff on bumper
Post #611950 Fri Mar 26 2021 6:55pm
Wayneclarke
have a listen if there ticking
Post #611954 Fri Mar 26 2021 7:43pm
Eaters
My sensors have started playing up again. I am occasionally getting the high pitched warning sound. Not the same symptoms as you as they still work sometimes. I will have to investigate as soon as the weather gets a bit warmer and initially I will start at the rears because I am very suspicious of the way LR routed the cabling. Andy K's comment about chafing is high on my list of possible causes.
This might help...https://www.rrsport.co.uk/forum/topic48459.html?highlight=parking+sensors Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #611962 Sat Mar 27 2021 7:29am
TrafficMan
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
Can the front offside corner sensor be replaced without taking the whole bumper off ??
Post #613267 Tue May 04 2021 8:20pm
Silverstone
They took my bumper off to replace the front offside sensor. Only cost me £250 for the diagnostics, part and fitting. There is no replacement for displacement - W O Bentley
Post #613268 Tue May 04 2021 8:27pm
